Carburetor Turbo DONE!
Old May 20, 2012 | 05:46 AM
  #51
mikebrock's Avatar
What exactly did you do to pressurize the carburetor? - as it looks as though you have a blow through arrangement. The carb needs to be sealed for instance - and other factors need careful consideration or it would simply lean out causing massive internal engine damage! You need to get the air/fuel ratio right which means ideally some work on the rollin road. - I hope you haven't just simply bolted the turbo's pipe to the carburetor? And what about compression ratio - if its a low pressure turbo system you've built - you maybe get away without having to lower it? Uprate the head gasket at least or it will blow! You need to look at ways to retard the ignition on turbo boost. Anyway enough for now....
Old May 21, 2012 | 03:54 AM
  #52
mastodon's Avatar
Originally Posted by 3gd16
does the bumper fit over the intercooler
Attached Thumbnails Carburetor Turbo DONE!-img00731-20120519-1727.jpg   Carburetor Turbo DONE!-img00730-20120519-1727.jpg   Carburetor Turbo DONE!-img00729-20120519-1707.jpg
Old May 21, 2012 | 08:53 AM
  #53
mastodon's Avatar
the turbo is pressurised by the blue "hat" on top of the carb, it seals 100%. why would you say im going to be leaning out? this engine has a lower compression rating than the injection version, the pistons also have 3 rings opposed to the 2 rings of the injection version. im keeping the boost at 0.4bar .my timing is on 10 degrees static now.
Old Nov 20, 2014 | 02:11 PM
  #54
robcoop's Avatar
Just to say like your build love cheap turbo setups, make me want to do a winter project on my very slow bmw m10.
Old Aug 21, 2015 | 08:51 AM
  #55
Minipup's Avatar
how's your nismo running? great job and nice effort. drive safe.
Old Aug 21, 2015 | 04:06 PM
  #56
dean924s's Avatar
It is so easy to punch holes in what others have done. People lighten up a bit. Is what he has done perfect? No, but dam he has a turbo car (I can not say that at the moment). I am impressed with your "get it done" mentality. I have been working on a project for way to long and I need more of your just do it and see what happens and correct things from there.
One thing I would do is fab up a pipe that replaces the inter-cooler so in a pinch you can replace it if some one backs in to you or something. Keep it in the trunk just in case.
Congrats on the build!!!!
bitchM0VE
Sep 21, 2008 08:37 PM
AccordX2Boost
Dec 12, 2006 10:16 PM
car_01
Feb 17, 2004 04:08 AM
ericg_0059
1
Sep 26, 2003 02:05 AM
snuffy
Feb 19, 2003 11:36 AM
