Rotating Center Section T3 (reviewing basics w/ pics)
Old Jul 31, 2006 | 01:42 PM
  #51
marc_vtec's Avatar
Default Re: Rotating Center Section T3 (reviewing basics w/ pics)
The joy of having a brand spanky new t3
All loosened with ease, no hammering here.
Cheers for the write up Jeff.
Old Aug 28, 2006 | 02:25 AM
  #52
d-t's Avatar
d-t
Took me so long just to clock the t3 60/63. Although I did use the 13mm wrench instead
Old Sep 4, 2006 | 09:52 PM
  #53
sharkytm's Avatar
I just followed these directions, and my 1989 Saab T3 came apart with little to no fuss. The bolts were soaked in PB blaster for a day, then I used a dead-blow hammer on the wrench. Thanks a ton.
You really have to wail on the exhaust housing to get it to pop off. I soaked it in PB Blaster too, and that helped. I'm gonna sand it with some fine paper when I reassemble.
Does anyone know where to get a new inlet housing gasket (The big circular one)? Mine tore when I opened up the inlet side. Would cutting one out of gasket material work ok?
Old Oct 12, 2006 | 01:40 PM
  #54
Smith-02's Avatar
if its thin as ----, yes.
Old Oct 16, 2006 | 11:32 PM
  #55
robrs2's Avatar
Had to turn mine around too, but 2 bolts snapped. These were drilled out and the treads cleared. The centre core also needed a bit of heat and the help of a hammer.
One of the bolt holes is open through to the exhaust as it is drilled all the way through. not the best design.
After
Old Nov 10, 2006 | 12:47 PM
  #56
rease3's Avatar
very good write up now i just need a write up on how to take the bolts out of the T3 Internal Wastegate Swing Valve and how to mount the wg acuator..
Old Nov 11, 2006 | 02:38 AM
  #57
rease3's Avatar
bump
Old Jan 16, 2007 | 08:30 PM
  #59
WTF's Avatar
WTF
lol @ me
heres what happens when you dont take your time backing them out a little then back in i guess, and probly didnt help the turbo was sitting in single diget temps..
4 out of 5 snapped on the downpipe side, none on the cartridge side
Old Mar 2, 2007 | 01:53 PM
  #60
sohc95vtec's Avatar
dang that sucks.. good write up none the less
