Rotating Center Section T3 (reviewing basics w/ pics)
Old Jan 25, 2006 | 09:12 AM
  #41
M I N I O N's Avatar
Default Re: Rotating Center Section T3 (reviewing basics w/ pics)
Originally Posted by wojo97civic
im sorry to bring up an old post but does anyone have a picture of relocating the internal wastegate actuator?
Be glad you don't have one of the ball bearing Nissan turbos.
They have a longer wastegate arm and bolt to the SIDE of the compressor housing instead of using two of the six compressor to backing plate bolts.I had to make my own bracket just to clock the turbo. Total BS.....
Don't laugh at the DP flange ... I had to make that sad little set-up and the internal wastegate thing just to get the car to the shop with the TIG where the turbo header and real DP got built.
Old Jan 30, 2006 | 05:51 PM
  #42
boostedJ's Avatar
i NEVER noticed the bolts being a bitch to get out ..... they all just came out nicely .....
however I was rebuilding the turbo ... so I had to hammer away at the exhaust side to get it to come apart.......I rebuilt the turbo in about 1.5 hours...... fun stuff...... just don't break anything ...... that gets expensive !!
Lee
Old Feb 20, 2006 | 09:25 PM
  #43
UltimX's Avatar
to rotate the cold side, you just loosen the 4 bolts (2 more bolts that arn't shown so a total of 6) in this pic on the cold side.
Old May 5, 2006 | 07:44 PM
  #44
ezspoolin's Avatar
what is his turbo off of? and whats with that bolt in where the coolant goes?
Old May 9, 2006 | 11:37 PM
  #45
speedy2000ls's Avatar
this might be a bumb *** question but how can you tell the oil feed from the oil return line?
Old May 23, 2006 | 06:42 PM
  #46
AJxr's Avatar
the feed is smaller hole, the return is the bigger... on t3s that is, im not sure about all turbos
Old May 30, 2006 | 01:43 AM
  #47
MVturboeg6's Avatar
in the pic it looks like u have a ebay boost controler those it work good im wanna buy one .. i also clocked my ct26 ill post pics soon
Old May 31, 2006 | 08:22 PM
  #48
i had to do this last weekend. you just saved my life.
thanks!
Old Jul 24, 2006 | 02:50 PM
  #49
king-of-the-hill's Avatar
Originally Posted by burkej62
This is an awsome post .. I was able to clock my cold side easily but i have all the bolts and plats loose ont he hot side and it wont budge it has been lubed, heated and beated but it wont budge am i missing somehting here?
i'm experiencing the same problem... sucks big time
there is NO movement at all, I've wacked the hell out of it
Old Jul 25, 2006 | 06:39 AM
  #50
finally
heating it up worked out for me, a few hits with Mr Hammer and it got loose
