91 Acura Legend TT build in progress and My official Noob post w/ newbie nudes
Old Dec 17, 2008 | 04:25 AM
Telion's Avatar
Default 91 Acura Legend TT build in progress and My official Noob post w/ newbie nudes
First I apologize the pics are not necessarily in chronological order it has been torn apart and put back together so many times that at this point it is all the same (undone); and for the build not being complete but I figured this would be a good opportunity for you to get to know me before asking questions, (most have been found by searching) But if you google Acura Legend Turbo you will see that I am going where few (can count them on one hand) have gone before so the Legend forum I am a member of is limited in this degree of car knowledge.
Now about Killanna (****. key-yana, yeah I named my car flame me
I bought the car a couple years back with a BHG and knew that the purpose of the car was to go as all out as I could afford on my limited income
Car: 1991 Legend Coupe 5 speed
Engine: 3.5l from an Acura RL
Pre-turbo build Mods:
pnp manifold
Type II springs,
Telion Chip,
HID's,
H&R springs
Koni Red shocks,
Addco Sway bars,
Type II dual piston calipers,
RH C2's,
short shifter,
EGR plate,
Stage III clutch,
S&D rotors,
KVR pads,
blackend engine damper,
CF hood,
AFC NEO,
Telion 3.5 Aluminum crank pulley,
Web cams I am also a distributor and can get group buy discounts if there's interest.
Now for the build progress parts so far
A pair of rebuilt T3/T4's (still being rebuilt will know trim once they are done)
450cc DSM Blacktop injectors
Walbro 255 Lph fuel pump
Aeromotive FPR
Trick flow fuel filter
Custom headers
C&R Racing radiator
Top fuel Zero1000 BOV, and catch can
Pro sport water temp, oil pressure, and boost gauges
Innovate LM-1 wideband and RPM aux.
Just Intercoolers dual 2.5" to single 3" intercooler
dual core oil/water cooler
Blitz turbo timer and boost controller
and a few other things that I will mention as needed.
Here is Killana
Progress pics
for those that are not familiar with the Legends engine bay there's not much room for anything
so alot of work had to be done just to accomodate a set of twins.
Now unfortunately it has not looked this clean since
The first step was a place to locate them I was going to mount them under the car but there was not enough room. So I later settled on the engine bay and attempted to modify a st of 350Z headers good idea but the headers would not fit and they were a cheap Ebay variety that were not worth modifying so custome headers were now a requirement. (where I met all of you for the first time) after reading the threads here I decided to build my own headers.
After removing several things I managed to make enough room for the twins and the piping that was to come along witih them
And this is basically where I am at so far in the engine bay
another shot with the BOV in place
A shot of the intercooler, suprsing that the front bumper managed to still fit
Now of course the couplers will be replaced but they are great for mocking up the build to see how much silicone will be needed.
Oil line setup
4AN Feed lines I am thinking I will need oil restrictors
full side shot, drain lines are 10AN
Here is a shot of the custom carbon fiber radio bezel I am working on since I am not big on gauge pods
The latest addition, justification potect it from heat.
Once the turbos are done I will have the downpipes welded and post updated pics if I am not flamed off the forum for posting an incomplete build
And now that you have read my book of an intro I will make it worth while. And honey if you see this it is really a forum requirement and I didn't enjoy any of these pics
Old Dec 17, 2008 | 04:29 AM
45psi's Avatar
Default Re: 91 Acura Legend TT build in progress and My official Noob post w/ newbie nudes
you forgot the porno...
Old Dec 17, 2008 | 04:30 AM
Telion's Avatar
Old Dec 17, 2008 | 04:33 AM
Telion's Avatar
Refresh for flesh. I could not forget that I want to be welcomed here There will come a time that I will seek the assistance of the PSI Pro's.
j3w's Avatar
j3w
bar none my favorite acura body style. ------- sick *** build.
Old Dec 17, 2008 | 04:34 AM
45psi's Avatar
zc
first i just scanned your very first post to see no ****, then i read the sentence, " Now about Killanna (****. key-yana, yeah I named my car flame me."
dude, your driving the short bus to homo-town
Old Dec 17, 2008 | 04:36 AM
45psi's Avatar
its a rule that all new posters/member post porno in their intro posts... seriously. the more **** you post, the more the members will like you.
Old Dec 17, 2008 | 04:44 AM
BoostForLife's Avatar
what are you going to control your timing with
Nice clean build, I like legends also.
Old Dec 17, 2008 | 04:52 AM
j3w's Avatar
j3w
resize that pic in your sig too
Old Dec 17, 2008 | 05:19 AM
Telion's Avatar
Thank you, and yeah I noticed the sig needs to be resized after I posted sorry about that I will fix it in a few.
Timing will be controlled by a Telion chip tuned on a dyno with an Ostrich and Tuner Pro. I have been working with the Legends air fuel maps for a couple years now. My primary engine management concern right now is the MAP sensor and related cels. I may end up in need of The Missing Linl or something similar
Ok a few more pics (more nudes to come too
A few things that have been done to make room
-The battery has been relocated to the trunk (no pics on that yet)
-The Map sensor box was tucked into the passenger side corner of the engine bay
-The ignitor box was moved to just infront of the passenger wheel well and the power steering reconfigured a bit
no pic of the PS but the plastic reservoir is replaced with a Zero1000 catch can
-The VIS solenoids were moved to the firewall (two are OEM the one on the right side is the boost controller
-The fuse boxes were moved to under the dash
-The cruise control and A/C were removed all together
-The Power steering hose was extended to tuck out of the way of the 3" exhaust (here tomorrow)
Not a relocation mod but I scored another aluminum reservoir that will be converted to a breather can
Found a shot of the Tig welded N1 style exhaust that will go on it my fellow Legend forum family is not too excited about this lol
but form follows function and she is going to need to breath
My favorite pic of the headers and mad props to my buddy for getting these welded at the cost of a ride once the car is done
Designing the headers the hard way lol
