Go Back   HomemadeTurbo - DIY Turbo Forum > Homemadeturbo > Engine Management
Old 07-23-2003, 10:39 PM   #1
tuning art
Default FMU AND 330cc Injector WorK foR 7 psi ?
Hi i have read all the FMU topic from 1 to 11 Lolz
I learn alots and i decied to run an FMU with mazda mx5 turbo injectors is the mazda injectors (satturate*)or peak and hold do i need a resistor box ? But what size of disk is best to run about 7 or 8 psi ? with stock pump can my d16 take 7 psi ? or it better off to run stock 240 cc injectors ? i really want to run AFC but it very hard to find DSM injectors and im in low buget . thanks ... any1 know where to buy FMU for cheap .... ?
__________________
Home Made Turbo mean that you made your turbo at home ... ?
tuning art is offline   Reply With Quote
Old 07-23-2003, 10:44 PM   #2
Sinner
Default Re:FMU AND 330cc Injector WorK foR 7 psi ?
If your gonna use 330cc injectors then get an afc or fields and ditch the fmu.
Nick
Sinner is offline   Reply With Quote
Old 07-24-2003, 12:54 PM   #3
tuning art
so it bad to run 310 cc injector with FMU i don't think im going with AFC it expensive it like $ 350 and the FMU is $150 so what size of disk to used with stock injectors and pump to run 7 max ? because 310cc with FMU is too rich ?
Old 07-27-2003, 01:04 PM   #4
Sinner
I'd recommend a fields controller +3XX injectors if your broke. I saw one going for 50 dollars used on honnda-tech.com. That would put your total to around 90$ if you pay 10 dollars an injector.
Nick
Old 07-28-2003, 06:00 PM   #5
d16forlife
Where the hell can I get injectors for 10 bucks each?
d16forlife is offline   Reply With Quote
Old 07-28-2003, 06:02 PM   #6
Dr.Boost
I'll sell you my stock ones for $10 a piece. :P
Dr.Boost is offline   Reply With Quote
Old 07-28-2003, 06:26 PM   #7
ZexRex
they are free at the junkyard haha
ZexRex is offline   Reply With Quote
Old 07-30-2003, 12:48 AM   #8
Sinner
thats the going rate in central louisiana. 10 bucks an injector if you pay for them.
Nick
- by 4g64t
