Water Injection 2008
Old Jun 15, 2008 | 12:12 AM
  #41
Chris Harris's Avatar
Default Re: Water Injection 2008
Originally Posted by turbo dave
so nobody still has numbers to look at what kind of gains were actually dealing with as far as meth/water and water
just adding water/meth on a honda will not net you any gains without tuning for it...IE leaning out the mixture and adding timing (effectively the same as switching to race gas)
Old Jun 16, 2008 | 04:47 AM
  #42
Schwitzer Turbo's Avatar
Originally Posted by Schwitzer Turbo
I drove the car around for about 2 weeks on Just water. then I increased boost with water meth to 1.8 bars did 100 miles in it. then we took it on the road for a Big HP tune. Insert Oil Splat here. anyway I have only got myself to blame...
so im Back on the road now, while i was down, my mate put WATER injection on his new spec Opel OPC Turbo, Originally it was pulling back 8-11 degress timing, with Water Only it pretty much solved that problem..
Old Jul 22, 2008 | 03:46 PM
  #43
Speeder's Avatar
generally, spraying water/meth decreases the power of the engine (no I don't have any concrete numbers) and what I always wondered is if the extra boost gains offset the losses?
Old Jul 22, 2008 | 04:06 PM
  #45
b18.'s Avatar
Originally Posted by jagojon3
Of course it does, why would anybody use it if they make less power with it?
Because that's what the cool kids do.
Old Jul 31, 2008 | 08:05 PM
  #46
tamago's Avatar
it almost seems that buying all the separate parts could get you into a nickel/dime situation pretty quickly..
has anyone here used MAF based controllers for water injection?
Old Aug 2, 2008 | 10:46 AM
  #47
b18.'s Avatar
I think you'd be better off with a Throttle Position vs MAP system. Having a transistor control the pump flow based on MAP voltage and a variable resistor on the throttle.
Old Aug 2, 2008 | 10:22 PM
  #48
Eville140's Avatar
Got around to installing my ebay kit today, still have race gas in the tank though. Once it is gone I will see how much boost I can get away with on pump with my normal amount of race gas timing.
Old Aug 3, 2008 | 12:15 PM
  #49
Bernardd's Avatar
I use the autospeed build it yourself kit on my datsun. So far I've kept the stock motor together running low 11's. After trying water/meth for two years, I've switched to 100% meth and lowered my et by 1.5sec. I have to spray a lot more with the meth, but it works much better than anything with water. A local tuning shop won the car craft dyno challenge using water only, but with meth they gain another4-500hp over the 1300 or so they made at the contest.
Old Aug 3, 2008 | 03:56 PM
  #50
I got my car mapped, running a snowboost kit, the 175cc jet comes on at .8 bar boosting 1.4 bar with Pump Gas and 50-50.
Eventually wanna run 1.8 bars on this setup....
