Old Sep 17, 2008 | 04:37 PM
-SKUM-'s Avatar
cant wate to hear it when its done
Old Sep 18, 2008 | 01:30 AM
aero's Avatar
If I can get a few things worked out in order to pass tech, I'm hoping to make it to the track the weekend of the 26th. need to get the 2 step hooked up so I don't bog it too. lol
It will only be at ~14-15 lbs and no intercooler so I don't expect anything very fast. Just wanting to get a baseline and have some fun.
Old Sep 18, 2008 | 10:31 PM
G2turbo_terror's Avatar
Originally Posted by aero
94 Galant 2.4l
Megasquirt 2E 2.01
E85
Very nice.
Did you have the car already running off of megasquirt before you started?
Old Sep 18, 2008 | 10:50 PM
drunkinmaster1's Avatar
that turbo with a 2.4 liter should be in heaven.
and a damn sexy turbo it is. full boost should sound like music.
get some vids a.s.a.p.
Old Sep 19, 2008 | 12:56 AM
Loserkidwac's Avatar
Wow I think i will look into that turbo for my build...keep up the good work!
Old Sep 19, 2008 | 02:55 AM
aero's Avatar
Originally Posted by G2turbo_terror
Very nice.
I had MS1E for a couple years, ran MS2E for about a month, then had some engine issues and the car sat for about 7 months till I could get time. I never had it running well on MS2E, just didn't have time to tune it well when it was running.
I need to find a buddy with a camera.
It actually sounds sweeter at low boost before the VGT opens from all the turbine whistle. The exhaust gets a lot louder and the turbine quiets down.
Old Sep 19, 2008 | 04:59 AM
WTF's Avatar
WTF
cool turbo. do those 2.4L (4g64?) motors interchange with any 4g63 motor and tranny?
Old Sep 19, 2008 | 05:17 AM
aero's Avatar
The only external difference between 4g63 and 4g64 as long as you stay within generation 6 bolt vs 7 bolt is 6mm of deck height. Ones that started life with an 8v head there are a couple holes that most people plug in the deck for oil drainback when swapping for a 16v head.
Other than that some don't have a hole threaded in the stock location for a knock sensor, but it can be relocated to another hole nearby.
2.4's that can be used:
6 bolt "4g64s" are the g64b, 7 bolt the 4g64, and 6 bolt hyundia's that are usable for a hybrid are the G4CS.
Hopefully I didn't ---- that up I'm a bit tipsy.
Old Sep 19, 2008 | 11:32 AM
Ok so now I'm searching for one of these turbos :P
how hard was it to modify the electronic VGT controller to make the wastegate actuator work? Since you are using the actuator technically you could use a boost controller to adjust when the vains open correct? have you messed with this to see if it has any affect on spool? or is it fairly good where you have it set now?
Old Sep 19, 2008 | 01:03 PM
cmr333's Avatar
yeah i wondering the same thing, if that thing is electronicly controlled couldent a electronic boost controller control that for you?
