DIY Two Way PCV System How-To (HoMedepoT style)
Old Feb 16, 2010 | 01:01 AM
  #111
teewakahn's Avatar
Originally Posted by Superorb
if you run a line from the pcv on the valve cover to a catch can, you can run the next line to a slash in exhaust or slash in pre turbo piping, and there won't EVER be positive pressure, there will always be vacuum. of course, there will be more vacuum in the exhaust than the intake htough. you shouldn't need any check valves that way either, since the flow is always going the same direction: away from the valve cover.
that would hav to be after the cat would'nt it?
Old Nov 28, 2010 | 03:42 PM
  #112
Dustyvip's Avatar
I have a catch can set up for my rocker cover which is working fine
But i want too fit a catch can for the bottem end now
i will have one feed from the black box(no PCV) and one feed from one of the oil plugs at the back/bottem of the block too the can
Do i need too put a vacuum line from the turbo intake too the can or just put a small filter on the can so that it can go in too the atmosphere?
Old Dec 9, 2012 | 02:34 AM
  #113
murtazadsm's Avatar
cant see pics
Old Jun 8, 2016 | 02:58 AM
  #114
karinsheng's Avatar
Default electric turbo core,car turbo actuator
I alway have some DIY car parts,turbo car and turbo cars.
Old Jun 22, 2016 | 01:48 AM
  #115
karinsheng's Avatar
Your Forced Induction is so useful that I collect other information from Zencar electric turbo supercharger
Old Jun 23, 2016 | 12:52 AM
  #116
karinsheng's Avatar
You can find out the Way PCV System from electric superchargers vs turbo.
scartail
Sep 22, 2004 10:14 AM
used2baracer
7
Jun 17, 2004 04:41 PM
DOHCZCEF9
May 17, 2003 01:50 AM
