ching chong turbos
Old Jan 21, 2009 | 09:31 AM
malibutwinturbo's Avatar
Default ching chong turbos
just how many of ya'lls are actually using meow mix turbos??
i'm considering CDM goodness for a cheap build...i doubt i can find a JY turbo thats big enough & in decent enough shape for what i want to do
Old Jan 21, 2009 | 09:43 AM
Default Re: ching chong turbos
of course then i just found this...not too sure if it will move enough air tho...
http://cgi.ebay.com/ebaymotors/REBUI...#ht_728wt_1593
Old Jan 21, 2009 | 11:27 AM
Hitchhikkr's Avatar
The general consensus is that they are junk. Ive seen them dead in less than 100 miles, but ive also seen them last 10K miles. Seems hit and miss, but the majority are miss.
They can be made reliable with garrett internals and such, but by the time you get it to that point, and paid for it to be rebuilt, you could have bought a 'real' turbo.
How long does it need to last is the question.
Old Jan 21, 2009 | 11:44 AM
i guess i'll stick with the tried & true good ----...i want it to be worth my while
Old Jan 21, 2009 | 11:58 AM
Tom-Guy's Avatar
Run the part number. Being a T04B I'm pretty sure it's somewhat down on power for the label "T04", the majority of T04B are the 340-370 whp units sold on Treadstone kits or that BLAAST turns out or else are 60-1, etc. That one might operate in the 400-ish whp range, but the turbine side is huuuuuuge.
Old Jan 21, 2009 | 02:10 PM
the turbine worries me, cuz this will be a RMT set up...with a 312 roller feeding it, looking for 400whp @ no more then 8-10lbs of boost
anyways, this is what i came up with after a quick search;
1976-1986 Navistar DT466A; 466CID16D- 180hp 2WCHP
it always seems to me, that a rough rule of diesel turbos is to get one from a truck having roughly double the displacement...HX35s are on 5.9s & people love them on 1.6-2.4L motors...so i need something from around 10-11L of displacement, that AR turbo is like 7.6L...so i'll guess i'll move on
Old Jan 21, 2009 | 11:51 PM
crx2211's Avatar
That Airesearch turbo on Ebay is good compressor wise. It's the V-trim compressor. You could find a JY T3 and use the turbine bits off it so you can have a T3/TO4B v-trim. You'll need a smallish turbine for a RMT.
Old Jan 23, 2009 | 09:53 AM
what about the T70 from evans...comes with a year warranty...i work at a shop...grrr, i dunno, getting married is phucking pwning my wallet
Old Jan 23, 2009 | 12:13 PM
Hitchhikkr's Avatar
That does happen. I was broke for a year after I got married.
Old Jan 24, 2009 | 08:10 AM
crx2211's Avatar
Why don't you just buy a giant Garrett off Ebay, find a good P-trim turbine wheel and turbine housing (I've got them for ya) and make a T4 with a P-trim turbine and like a 4088 compressor side? Prolly get it done right for $400>. Lots of options like that. Or just buy a TO4S off Ebay for like $110, source a T31 turbine and housing (I got those too) and then build a T3/TO4S?
