obd0 to obd1 swap
Old Mar 31, 2012 | 08:16 AM
AFTeg's Avatar
Default obd0 to obd1 swap
I have troubled shooted it for a couple of hours and I am not sure what I might be missing. I have done a few searches and still not sure. Here is my problem.
I have 90 teg with b18a running p30 with crome map and a obd1 dizzy. Car will start but I have to keep the throttle open to keep it running, otherwise car will die. When I hook up EcuControl it will say that Im doing 177mph when its not started. and it will not read the rps at all. TPS reads correctly so does IAT. I do get a check engine light but I have not pulled the codes on it yet. Plan on doing it today after I wake up. I have checked all thr grounds and the base map is good. What am I missing?
Old Apr 22, 2012 | 11:07 AM
Brent636r's Avatar
your trouble codes...
Old Apr 22, 2012 | 05:01 PM
AFTeg's Avatar
Fixed all the codes. I was still in limp mode until I cut j1 so i assume my chip was bad as well. Do chips just go bad? it was a working chip it sat in my garage for a long time and all of the sudden it stopped working.
Old Apr 24, 2012 | 06:25 PM
Surriolo's Avatar
thank you very much)) good information))
Old May 2, 2012 | 06:55 PM
utinage's Avatar
Wow!) Great post, thanks!)))
projekteg
13
Jan 17, 2006 10:14 AM
90turboteg
5
Jul 10, 2005 11:48 PM
90turboteg
Jul 10, 2005 12:26 AM
Chris Harris
Feb 13, 2005 10:45 PM
Sirex
May 22, 2003 11:39 AM
