Quote:
Originally Posted by hondavtec4208
Is your ECU chipped? If so make sure the chip is not in backwards. The half circle mark on a chip that goes into an ECU should always point to the ECU connectors. I had this happen once when i put a chip in backwards in the dark oops
Had this problem even before the ecu was chipped so we had to hardwire the fuel pump so we can use the ecu. Had it chipped trying to troubleshoot the problem via chipping; guessed wrong. We were able to use the ecu for tuning and apply features like revlaunch but we guess the main relay problem is separate. Was trying to have more info on the qm3 part.
