Filling Block... How To.... UPDATED
Old May 4, 2005 | 11:08 PM
  #81
z6efboosted's Avatar
Default Re: Filling Block..... How To
hey crx304 i seen your update on your car in generall discussion and i noticed you didnt block fill the new motor. why not having problems with it. i just block filled mine tonight. hopefully it works. im kinda scared now i seen you didnt do it, since you did that huge write up on it. let me know. thanks chris fox
Old May 5, 2005 | 02:50 PM
  #82
Foowee's Avatar
A buddie of mine mentioned sugar maybe less corrosive than salt. Does anyone know if this is true?
Old May 5, 2005 | 03:23 PM
  #83
90turbohatch's Avatar
I think you got this backwards. Correct me if I'm wrong, but I believe his old motor had block posts. His new motor is filled.
Old May 6, 2005 | 01:53 PM
  #84
crx304's Avatar
correct....
old motor = posts
new motor = filled
filled motor = good
good = happy
happy = ownage
ownage = priceless!
mike
Old May 6, 2005 | 03:37 PM
  #85
B16Drag's Avatar
Originally Posted by crx304
correct....
old motor = posts
new motor = filled
filled motor = good
good = happy
happy = ownage
ownage = priceless!
mike
I understand the whole block posting and filling. I also understand that you had to drill in the holes through the filling after the fact. Since you have done the block filling ordeal, do you think there would be a much more efficient and safer way of making those holes rather than drilling through them? I was thinking of putting straws or sticks in before pouring in the aluminum Just a thought. Reason I ask is I'm thinking block filling my LS block...
Beau, wanna share the secret method y0?
Old May 7, 2005 | 08:15 PM
  #86
correct....
old motor = posts
new motor = filled
filled motor = good
good = happy
happy = ownage
ownage = priceless!
mike
so i take it that the filled motor is working out good. because i just got done doing mine and it turned out real good, well i think so!!!!!!!!!
Old May 8, 2005 | 09:23 PM
  #87
this is what ive done the past few days
Old May 8, 2005 | 09:26 PM
  #88
tranceminister's Avatar
Looks good Z6ef. How did you heat yours so it would harden? Did you do it as crx304 stated using heater's etc.?
Old May 8, 2005 | 09:33 PM
  #89
i put mine straight in the oven at 200 for 4 hours. i think it turned out good . thanks to crx304
Old May 8, 2005 | 09:43 PM
  #90
crx304's Avatar
that's what i like to see!!!!
do those holes in the filler match up close to ur headgasket?
looks real good!
mike
