Filling Block... How To.... UPDATED
Old Apr 21, 2005 | 08:04 PM
  #71
absolutezroo's Avatar
Default Re: Filling Block..... How To
it makes sense if your getting it milled...however don't you want space left at the top of the fill and the top of the block? if you filled it upside-down then you'd be flush with the block
Old Apr 21, 2005 | 09:31 PM
  #72
TorganFM's Avatar
How would you even fill it upside down? Pour it through the hole that you normally tape up?
Old Apr 22, 2005 | 04:27 PM
  #73
juli0_bustamante's Avatar
thats what im guessing...:P
Old Apr 26, 2005 | 01:04 AM
  #74
bumblezc's Avatar
I think if you wanted to fill it upside down you would seal the top of the block with a peice of steel/wood/plastic, flip the block upside down and somehow fill the block using pressure through the water pump inlet to get it everywhere throughout the block.
My guess is it would be more effort then it's worth!!!!
Old Apr 28, 2005 | 09:58 AM
  #75
BLACKSI's Avatar
a little space at the top of the block is not going to hurt anythig, besides thats not were you need the support
Old Apr 29, 2005 | 04:09 AM
  #76
95civic's Avatar
Need updata, hows that shiznit running?
Old Apr 30, 2005 | 09:39 AM
  #77
crx304's Avatar
it's running great!!! 3000+ daily driven miles in 60-75 degree weather @ 15-17 psi.....looking to upgrade the turbo now! temp gauge hasn't gone above 1/2 way whatsoever w/ T-stat installed.
cant wait till the 90 degree days!
mike
Old May 1, 2005 | 05:28 PM
  #78
95civic's Avatar
------- sick im gonna do this for sure then
Old May 3, 2005 | 06:37 PM
  #79
J-MAN's Avatar
did you just reuse your stock pistons and rods? about how much HP do you think it is putting down at 15-17 psi?
Old May 3, 2005 | 10:24 PM
  #80
crx304's Avatar
click my sig for the info on my setup. 15-17psi...... hmmmm dunno!
