NOOBS! *LOOK HERE IF YOU WANT TO BUILD A TURBO KIT!* All info+stock WG settings
Old Sep 22, 2008 | 02:35 PM
  #41
901tuner's Avatar
Default Re: NOOBS! *LOOK HERE IF YOU WANT TO BUILD A TURBO KIT!* All info+stock WG settings
ok soi have a question! its problably been answer before but don't feel like searching for the answer so hear it is. So me and my friend just turbo this 1991 honda crx with a d16z6 engine in it. I read on yas websites of wat are things that can be needed so far but the car acts up all the time when i punched above 6000 rpm's. the engine light alwayscomes on so i have to turn the car of and crank it back on for it to be able to work. i don't know wats wrong with it. does anybody know wat could be going wrong? maybe gas flow or some like that.
Old Sep 22, 2008 | 02:42 PM
  #42
stenseltizm's Avatar
I know the answer but I don't fell like giving it to you
SEARCH YOU ---- AND DON'T CLUTTER UP THE STICKIES WITH USELESS BULLSHIT OR BDVT WILL HUNT YOU DOWN AND FIST YOUR MOTHERS -------
oh and your car is fine except the vac line running from your wastegate needs to be run directly to your blow off valve and nothing else, then the MAP sensor is throwing a cel so you need to pull the vac line off of it and plug it.
Both common mistakes among first timers.
Old Sep 24, 2008 | 02:34 PM
  #43
901tuner's Avatar
ok but some other people it had something to do with the map sensor and than they told me to get one from a chevy truck or some like that. they said it had 3n wires and it would make it work
Old Oct 9, 2008 | 08:15 PM
  #44
turboknightmare's Avatar
where is best place to get the oil feed line and fittings? (for honda d engine...)
the url listed in the first post no longer works...
Old Oct 9, 2008 | 08:50 PM
  #45
lock-pop!'s Avatar
http://www.---------------------------/
Old Oct 9, 2008 | 09:35 PM
  #46
o snap
thanks!
Old Nov 9, 2008 | 05:39 AM
  #47
PowerGirl's Avatar
SWEEET!
Old Nov 9, 2008 | 06:45 AM
  #48
j3w's Avatar
j3w
Originally Posted by PowerGirl
SWEEET!
hi mr. coleman
Old Feb 16, 2009 | 10:22 AM
  #49
imburne's Avatar
excellent thread even for the age.
Old Apr 8, 2009 | 04:40 PM
  #50
cobz436's Avatar
this is great
