NOOBS! *LOOK HERE IF YOU WANT TO BUILD A TURBO KIT!* All info+stock WG settings
Old Jul 21, 2008 | 01:17 PM
sciff5's Avatar
Default Re: NOOBS! *LOOK HERE IF YOU WANT TO BUILD A TURBO KIT!* All info+stock WG settings
Wow thats a very simplified break down. I've been lurking a little while and I am shocked people even had that type of question (you could have figured out most of that stuff from reading www.howstuffworks.com). My noob question I guess is a little more involved than the stuff the OP went over.
I am still baffled by turbo maps and how to read them, also the I could use some clarification on the A/R ratio. I know it effects how fast the turbo spools but I'de like to get some more info.
Old Jul 21, 2008 | 05:35 PM
b18.'s Avatar
http://www.enginelogics.com/cmaps.html
the A/R ratio.
Area of the exhaust inlet over the radius of the exhaust housing (from center of turbine to center of exhaust inlet).
Think about what happens to a gaseous fluid that moves from a large port to a smaller port gradually.
Old Jul 21, 2008 | 05:56 PM
b18.'s Avatar
ok
Old Aug 4, 2008 | 09:20 PM
dzaazter's Avatar
Anyone have a detailed write-up like this for a 1994 civic hatchback? This will be my very first install so I need as much info as possible. Thanks
Old Aug 4, 2008 | 09:21 PM
NIGn0g's Avatar
Tayeule!
Old Aug 6, 2008 | 03:52 PM
b18.'s Avatar
---- you ******. Go back to being forcefed ***** while watching a gang of negro urinate in your mother's anus.
Old Aug 21, 2008 | 02:05 AM
jackfrost1031's Avatar
Originally Posted by keelay
how about someone with a more broad knowledge attempt to put up stock injectors and flow rates form various vehicles. i could do a few, but im talking on the scale of what ol guy did with the stock turbos and stock w/g settings. that would be very beneficial to alot of people.
here is just that for toyota injectors:
http://www.geocities.com/MotorCity/P...Injectors.html
Old Sep 13, 2008 | 01:39 PM
cantgetright420's Avatar
i was reading about tuning.. what is an ostirch? or how ever you spell it...and what do people mean by "burning a chip"?? i want to run crome on my jdm dohc zc motor, but it uses obd0 and idk tooo much about all that...maybe someone can help me out?
any info would be appreciated...thanx
Old Sep 18, 2008 | 05:11 AM
b18.'s Avatar
pgmfi.org
GO.
