Question: Will a t3/t04e 60 trim ar .63/.70 be to laggy on B20
Old Jun 9, 2006 | 09:21 AM
CivicComingSoon's Avatar
Default Re: Question: Will a t3/t04e 60 trim ar .63/.70 be to laggy on B20
I would strongly advise you to stay around 6-8 psi on a B20. I see you have some studs for the head, but its the walls that crack on the block on the B20's. GL.
Old Jun 9, 2006 | 11:31 AM
Jcushing's Avatar
Originally Posted by levan634
CC-Fab log manifold (havent gotten it yet)
Old Jun 9, 2006 | 02:08 PM
accordepicenter's Avatar
depends on the setup but it should be good to around there. On my 2.0 A20 the .60/.63 worked good, fully boosted by 4k, big top end etc
Old Jun 9, 2006 | 06:34 PM
levan634's Avatar
Originally Posted by Jcushing
yeah its been ------- 4 months and he still is making excuses...basically i got owned...
Old Jun 9, 2006 | 10:19 PM
RlinR's Avatar
Yeah I feel you, i got owned too
Old Jun 13, 2006 | 04:23 PM
drintegra's Avatar
Log mani with 3" Down pipe, running 9psi and boost on the b20 starts at 3 and full boost is in right below 4k rpm. Sick setup surprises alot of unsuspecting individuals. this is with the t3/t4 60 trim. Garrett
Old Jun 13, 2006 | 11:02 PM
0b00st0's Avatar
I'm assuming that's with a 0.63 A/R on the turbine?
Old Jun 15, 2006 | 04:17 PM
ju-on's Avatar
I have a different engine, but it's the same displacement, it's a 2.0L. I now run a mitsu hybrid 50trim, but i used to run a full garrett t3/t04e 50 trim compressor wheel with a stage 3 .63AR exhaust. I'd hit full spool right around the 4k range up until redline at 7k. I wouldn't consider it too laggy in my book. Great street/strip turbo in my opinion.
93turbo16
Feb 13, 2006 03:00 PM
ATX45
Sep 18, 2005 11:00 AM
elpiar
Aug 12, 2005 01:47 PM
