Turbo Yamaha Snowmobile
Old Dec 27, 2011 | 10:08 AM
damn you!!!! i want to ride it too!!!!!!!!!!!!! that looks like one hell of a fun ride.
you dont have to wait for snow. put some paddle tracks on it and ride it over a pond/small lake...
Old Jan 7, 2012 | 07:09 PM
tjc's Avatar
tjc
so I could not wait for snow, I took it in my moms field on the grass. It ran well, I am excited for sure. It hit 6 PSI boost in no time. I have a question, the BOV did not seem to open at all. I have a older Greddy RS valve, anyone have experience with these? I have it real lose but no whoosh when I let of the throttle.
Old Jan 9, 2012 | 08:38 AM
you need to adjust the bov spring rate. the bov should be closed at idle vacuum and open at closed throttle load vacuum. when you close the throttle under boost the vacuum signal will spike over the vacuum signal you would get at idle. this is the only time you want the bov to open. if its not opening then you need to replace the stiffer spring with a lighter spring.
Old Jan 9, 2012 | 09:05 AM
tjc's Avatar
tjc
I think it needs a new spring, it is loosened out pretty far.
Old Jan 9, 2012 | 10:24 AM
you may have to order lighter springs from greddy or try and cut the spring.
Reddy
Jan 26, 2017 10:54 PM
Mountain man
Fabrication
9
Oct 24, 2011 02:40 PM
tylermts
Aug 12, 2011 08:41 AM
