Anyone use the Energy suspension Bushing kits?
Old Feb 18, 2005 | 10:55 AM
necro's Avatar
Default Re:Anyone use the Energy suspension Bushing kits?
My trailing arms are not on my car yet so that made it easy to do the job and helped it dry better. I'm still running drums and will swap to disc maybe by spring.
Old Feb 18, 2005 | 10:57 AM
SkunT's Avatar
Originally Posted by julio_bOOstamante
my stockies in the rear are metal to metal :P
WTF?? how so? did you weld them :P
no, they tore out :P
who the ---- is this newb? hes a ------ post -----! STFU nooob. :P
-and i heard those bushings are awseome, but impossible to put in without good lube and a press
i have some bomb *** lube ( KY is your friend) and as far as a press..you dont need it..just get a big *** washer and some patience. I have a hondatuning article that shows you how to do it. i have to find it and scan it!
just make a "the mexican way to install new ES bushings" write up :P
Spenser's Avatar
you use big washers and some bolts to 'tighten' the bushings in. you also might wana check out this sight about the trailing arm bushings
http://www.performanceforum.com/wesv...g/bushing.html
idiot-stick's Avatar
yes, please
Old Feb 18, 2005 | 10:59 AM
juli0_bustamante's Avatar
good ---- spence
that guy Wes is awsome!!! hes an HT guy but i wont hold that against him.
Hes a So Cal Local from winetka, CA
and yeah thats where i read about them being bigger than the civic traling ar bushings
Old Feb 18, 2005 | 11:09 AM
yes, please
I'll look for it tonight. its the one from like 2003 when one of the editors boutgh a 2nd gen 4 door DA and re-did all the bushings. good stuff
Old Feb 18, 2005 | 12:47 PM
Racintweek's Avatar
i have half of them installed on my hatch, you dont need a press or the bolts and washers to put them in, use a torch to melt the rubber, a sawz-all to cut out the shells, then beat them bitches in with a hammer and a piece of wood.
to make them slide in easier take a wire brush to everything.
Old Feb 18, 2005 | 01:04 PM
If you're a super lazy ---- such as myself, could you pull off the window weld trick while the trailing arm is still on the car?
My bushings are shot to ----, so id have to rig up some 2x4's or something to keep the bushing centered while it was curing, but i figure it'll work out okay.
Old Feb 18, 2005 | 01:11 PM
necro's Avatar
I don't know about window welding it while it on the car. But when i did mines it wasn't on my car.
It might not dry right while it's on the car. But it depends on the weather where ur at i suppose.
Old Feb 18, 2005 | 01:33 PM
i would think it would work with the car on jack stands and it sitting for liek a good day or 2. Do it on a weekend and it should be ok . start friday night and borrow the girfriends car if you have to go somewhere
andif i were you i would use polyurithane( unless window stuffis poly ) then you should be OK. A heat gun helps curing time
