Idle air control valve
Old May 27, 2007 | 09:37 PM
  #101
Sinner's Avatar
Originally Posted by GimpyCivic
This diagram sucks, but see #13? under the TB? That whole the large dingus is the FIV. Fast Idle Valve. It has a thermo-wax plug that when cold.. opens and allows more air into the intake tract to warm the car up quicker/help cold idle. As coolant temp rises the wax expands and closes it. What happens is over time the wax plug gets messed up and it sticks open or closed.. usually open unfortunatly and it plays hell with the idle... especially warm idle since the ECU is then in closed loop operation.
Some FIV's are on the bottom/side of the TB.. some are on the intake manifold itself. It just depends on the year/make of the Honda.
As you can see above I keep 2-3 of these on hand at all times... kinda like igniters and OBD0 distribs :P
I believe my FIV is bad, Its been kicking my *** for about 3 months now.. but that seems to be the cause now that I can track the flow of air through the FIV by plugging the hole in the throttle body.
I'm thinking about permenatly closing mine... what the bad about that?
Old May 27, 2007 | 11:12 PM
  #102
Sinner's Avatar
Default Re: Idle air control valve
FIV was my problem, I'm glad I got it fixed!
Old Jul 26, 2007 | 06:06 PM
  #103
ezprelude8888's Avatar
i have a 97 h22. same thing on my car. revs up and down until warmup.
sucks!
i cheated and fixed it using programible AEM ecu
Old Jul 26, 2007 | 10:27 PM
  #104
b18.'s Avatar
Holy back from the dead batman! Homeboy digging up deceased threads!
Old Jul 29, 2007 | 03:42 PM
  #105
b16aturbohatch's Avatar
ok so here is what mine is doing. i start my car up then let it sit for awhile hit the brake then it will start reving up and down. sometimes once the fan kicks on it stop reving up and down also. i leave my tubo timer on and walk away it straights out after 20 sec of running. i have clean out the icav ------ card clean around trying to find a vac leak and nuttin any ideas??iwhen im at a light and it starts doing that i can hold the brake and let the clucth out a litt and sumetimes get it to stop reving up and down. could i be having volt probblems?? i am blowing alternator solenoid valve fuses when i drive the ---- out of the car. have a b16a in a ef p28 chipped
thanx
Old Jul 29, 2007 | 03:45 PM
  #106
b18.'s Avatar
This thread is dead.
But is it like the idle is loping or the car is threatening to stall?
Start a new "help me" thread.
Old Nov 18, 2007 | 07:59 PM
  #107
rosario4124's Avatar
+1 i had that same butterfly problem when i had my old skunk2 TB (you know back when skunk2 had the problem that the butter flys would not close on their TB's some stupid factory defect ) that made my car idle like complete ----
Old Nov 18, 2007 | 08:10 PM
  #108
b18.'s Avatar
Goddamnit
Offhand comments shouldn't go in stickied sections.
Besides everyone knows that skank2 are a bunch of china-hiring-skam-artists-***-*******...
Old Dec 2, 2007 | 11:59 AM
  #109
da9wonder's Avatar
i know this thread is very old but did anyone check the map sensor because it sounded like your guy's problem. have you guys tried disconnecting the map sensor for awhile to see if it goes back to normal idle?
Old Dec 2, 2007 | 03:17 PM
  #110
b18.'s Avatar
---- you stupid ***.
Read how to make your first post.
MAP sensor isn't going to lope your idle, it's going to make the car run like *** at part throttle, or barely idle at all.
