CEL on crx
Old Nov 12, 2011 | 11:46 AM
nguyen12600's Avatar
Question CEL on crx
My check engine light is lighting up when i start to get some boost
after it turns on my car seems to be lacking a bit of throttle response
and doesnt like to stay at a constant rpm. what could it be?
My Setup:
SOHC zc
VJ11 turbo @ 4psi
FMIC
Vortec FMU
Ebay Fuel Pressure Regulator
Ebay Bov (To atmosphere)
350cc injectors
walbro 255 fuel pump
i was maybe thinking it was the bov but im not sure ive tried adjusting the spring energy but no luck
Old Nov 14, 2011 | 11:57 AM
brettsb16a2's Avatar
First you need to see what code is stored. Second i bet you are super rich. A FMU is not real fuel management. At least run a AFC Hack. Is this OBD1 or 2?
Old Nov 14, 2011 | 01:13 PM
well im running obd0 and its flashing 7 and 20
i looked up the code and it said it was the tps sensor and electircal load detector......
Old Nov 14, 2011 | 09:47 PM
Never mind i found out what it was i replaced the tps sensor and it was all good
-SKUM-
May 13, 2007 03:17 AM
Turblow
Jun 4, 2006 06:59 AM
Dr.Boost
Apr 9, 2003 07:50 AM
2000psi
Mar 20, 2003 08:16 AM
TurboEF9
9
Mar 5, 2003 11:16 AM
