I REALLY NEED HELP! WHITE SMOKE AND OIL
Old Jul 17, 2011 | 06:21 PM
AJRMK's Avatar
Exclamation I REALLY NEED HELP! WHITE SMOKE AND OIL
Hello everybody!!
i finished with my home made turbo set up for my buggy and it start fire right away but , some how i have oil coming out from exhaust and makes white smoke when i press pedal.
what the problem is? i cannot figure it out. its new turbo t15
maybe wrong oil feed line? switch other side or?
here the picture of turbo and oil line
and here the video how it work you will see oil coming out and white smoke.
Attached Thumbnails I REALLY NEED HELP! WHITE SMOKE AND OIL-2mpbzat.jpg   I REALLY NEED HELP! WHITE SMOKE AND OIL-5a04ts.jpg   I REALLY NEED HELP! WHITE SMOKE AND OIL-2mpbzat.jpg   I REALLY NEED HELP! WHITE SMOKE AND OIL-5a04ts.jpg
Old Jul 21, 2011 | 08:16 AM
badmanbaz's Avatar
looks like the oil feed and return are the wrong way round to me
Old Jul 21, 2011 | 09:04 AM
oil feed is the smaller hole and the oil return is the bigger hole. if you look into the oil feed side of the turbo you should see a small restrictor built in. if you reverse these the oil will escape through seals as the oil drain side is not designed to see oil pressure.
Old Jul 21, 2011 | 09:08 AM
also. your oil feed line should not be that big. -3 or -4 line at the most.
Old Jul 21, 2011 | 09:18 AM
badmanbaz's Avatar
yeah i would leave the hoses the way they are on the turbo and connect the braided line to the oil feed and the thicker tube to the sump, its only gravity return the less restriction the better
Old Jul 21, 2011 | 06:48 PM
AJRMK's Avatar
i already switch to side and still have white smoke but oil stop leaking.. i also have oil restrictor and still do the white smoke and when i remove the exhaust to see if oil coming out from exhaust and it does very slow.
already did and still do the same? have any idea? how will i know if turbo bad?
Old Jul 21, 2011 | 06:53 PM
the damage may have been done already. pull the turbo apart and replace the seals. is this a garrett gt15 turbo or a knockoff?
Old Mar 18, 2012 | 07:24 PM
dean924s's Avatar
Are you running antifreeze? If the white smoke smells sweet (like antifreeze) it could be a Head Gasket.
boostedD26
Apr 16, 2007 11:03 PM
crxfreak88
Jan 10, 2004 12:40 PM
Turboteggy
May 4, 2003 01:24 AM
