Go Back   HomemadeTurbo - DIY Turbo Forum > Homemadeturbo > Engine Management
Old 05-02-2010, 12:22 PM   #1
spoolline
Default which version of mega squirt to use
i'm gearing up to start a mega squirt conversion onto a late 70's ford 2300cc engine with mild mods which mega squirt version is best for this application i'm considering switching over to edis ignition if this help's lol i know is a newb question
spoolline is offline   Reply With Quote
Old 05-05-2010, 05:49 PM   #2
ososlow
ms 2 will work just fine for you... but ms3 has more features and can datalog, the big thing about ms3 is that it can do sequential injection on v8s. ms1 will probably work but we usually just use it on fuel only applications.
ososlow is offline   Reply With Quote
Old 05-07-2010, 11:00 AM   #3
3258
I would go with the MS3 for the on board data logging, sequential injection, and it also has built in coil on plug capability if needed.
3258 is offline   Reply With Quote
Old 05-07-2010, 01:21 PM   #4
ososlow
hmm i was assuming the 2300cc ford is a 4 cylinder in which case ms2 will do sequential injection just fine. but if you really want to pay double just to have data logging go for it
Old 05-07-2010, 02:59 PM   #5
3258
The standard MS2 has 2 injector outputs , unless you run some extra hardware and the extra code etc, its not true sequential. I run bank to bank on my v8 through 8 low Z injector drivers on the MS2. The MS3 is worth the extra money IMO, and the datalogging is nice. For the unassembled kit, MS3=$365, MS2=$247 Check out DIYautotune.com
Old 05-07-2010, 08:00 PM   #6
3258
Also note that MS3 has MAF fueling calculation capabilities, here is some more info
MegaSquirt-3 Features
Old 08-08-2010, 01:20 AM   #7
AE101Jun
Make: Toyota
Year: 1994
bringing this to life... would MS3 control VVTi?
AE101Jun is offline   Reply With Quote
Old 08-08-2010, 07:35 AM   #8
3258
I don't think that is a standard capability of the MS3, but it seems like someone was working on a way to control that with this unit.
Some people using MS have a simple on/off switch on the VVT so it is either full on or off
- by 4g64t
