heres my wagon and my home made turbo mani tell me what ya guys think
so i just bought my rt back after selling it 2 years ago, and i missed it ever since so i finally got it back. as of now it has a d16y7, i need to make some sort of bracket to hold the half-shaft, i need to put the y7 oil pan back on, i need to but a alternator belt, have to get the ac likes and compressor, have to install the a6 flywheels and install the new clutch that i already ordered. it needs a new windshield, need a rear hatch window they installed like a 86 window or something cus its short like 3/4 inches on each side. i sold the car about 2 years ago for $2400 and i bought it back for $390 yes three hundred and ninety dollars lol.
Future mod:
gsr blades or se sunflowers
some type of sway bar for the rear maybe a modded da one, i have a welder and i fabricate alot, some aftermarket lca
polyurethane filled motor mounts and rear trailing arm bushings
-turboing the y7 using a tiny k03 turbo(which i already have) from a passant 1.8t should be very fun, making the manifold out of home-depot gas pipe elbows, dsm side mount intercooler and dsm 450cc
i got skunk2 coilovers i wanna install but i had put tein lowering springs in the rear and cut in the front, so for sure the skunk2 in the front but i dont know about the rear yet, i wanna lower the rear and front a lil more
tell me what u guys think and if anyone got question u are free to ask them....
this is how it looked when i went to pick it up i had to shovel it out
now in front of my house
so i was at the junk yard today heres what i found today, i found some dsm 450 injectors of a eclipse gst auto for $40 also found a da sway bar for 10 bucks, the y7 oil pan i found it for 20 buck and am picking it up tommorow...i also finished putting together the home made turbo manifold here are the pics....
started out with a stock y7 manifold
here the piping from home depot and what is supposed to look like
i had to cut off like a 1/4 inch on the end elbows
now the welding
finished product before paint
and painted next to my k03 turbo
here are the pics of the turbo and the injector and the sway bar and bov
just to give u a idea of how tiny this thing is haha i love it no homo
welding on cast requires a nickel rod and its still not very structurally sound. over time from heat the welds are known to crack. but ive done it and not had a problem i believe it depends on the amount of carbon mixed in.
if im not mistaken the pipe you get from home depot is galvanized. you must remove the galvanized coating before welding as it produces a deadly gas adn it can kill you.....
