Go Back   HomemadeTurbo - DIY Turbo Forum > Homemadeturbo > Hybrid/Tech
Old 02-03-2010, 02:35 PM   #1
ThedurtyDC2
Make: Acura
Year: 94
Default Will a p72 Gs-r oil pan fit on a b16?
Will a p72 Gs-r oil pan fit on a b16? I have a spare one laying around, I'm wanting to get it tapped and run that on my boosted b16. Will it clear the oil pick up and girdle?
ThedurtyDC2 is offline   Reply With Quote
Old 02-05-2010, 06:38 PM   #2
BlackTeggy90
Make: Acura
Year: 1990
No but from my understanding the B16 and the LS B18 oil pans are the same
BlackTeggy90 is offline   Reply With Quote
Old 02-08-2010, 03:11 PM   #3
Velisma
Make: Honda
Year: 1995
I thought all B-series oil pans were the same... regardless if it's vtec or non-vtec... I think it will... look on honda-tech.com. I have found a few threads regarding oil pan fitment and the general consensus is that all B-series oils will fit... Good Luck
Velisma is offline   Reply With Quote
Old 02-08-2010, 04:48 PM   #4
BlackTeggy90
Make: Acura
Year: 1990
It should fit i mis read the topic thought he said B18. But not all the pans are the same a GSR pan will not go onto a B18 LS
Old 02-15-2010, 10:30 AM   #5
Slo_crx1
Slo_crx1's Avatar
Make: Mitsubishi
Year: 2003
I can verify that B16 and LS pans are the same. Don't know about the GSR pan though unless it's from a B17 GSR (and then it will fit) lol.
Slo_crx1 is offline   Reply With Quote
Old 06-01-2010, 12:04 PM   #6
Superslow95
Default Ans
Ls and B16 are the same
to run a GSR pan you have to run a GSR pickup and that's sketchy cause only the 2 bolts on the pump can be used
and a b17 is a b16 basically so it will work also
Superslow95 is offline   Reply With Quote
- by chenzob
- by CreeK
