BIN file depository (TE, Uberdata, Crome, etc)
Old Dec 13, 2005 | 11:32 AM
  #81
Default Re: BIN file depository (TE, Uberdata, Crome, etc)
Originally Posted by Smooth_Imports
Was wondering if someone could point me in the direction of a good start up map for my new motor, Using uberdata
Start with a stock LS .bin, modify it from there for injectors, MAP sensor, + suchlike.
HTH
Old Dec 13, 2005 | 11:52 AM
  #82
Smooth_Imports's Avatar
there is no stock LS bin in 1.7
Old Dec 13, 2005 | 12:11 PM
  #83
Which 1.7? There have been about seven variants. Blake Warner is a lazy little less than white ----------er who did a horrible job of sensibly labelling upgrades and betas.
FYI, you need to splice LS maps into GSR code to get everything working correctly with most 1.7's.
I'm giving you short, sarcastic-*** answers that don't really tell you anything, because - while not hard - there are a lot of little things you are best off knowing before you make your own basemap, burn a chip, etc. It's all done up, in this forum, in DIY how-to's easily found when searching. It's either you do the homework now, or you get the stress and confusion of the "now it doesn't run right, CEL" thread we get four of a week here. If xeno's going to be your tuner, he may be inclined to hold your hand, but the rest of us want you to search for the how to make a basemap thread.
uberdata.pgmfi.org also has a lot more UD-specific stuff. hint hint.
Old Apr 12, 2006 | 04:55 PM
  #84
UltimX's Avatar
I'm suprized there isn't a base map for all the programs out there. I don't know if UD, Crome have any but TE didn't. I don't have a burner or i would test my base map i made. lol
Old Apr 13, 2006 | 04:26 PM
  #85
Die.
Old May 1, 2006 | 03:17 AM
  #86
bigdaddyvtec's Avatar
Ive got one for a stock f22(b1) tuned with crome pro/p72:
max af was 12.0 in boost
vtec at 4000
cant remember timing, but conservative, NO PINGING on Super -92
t3/04e 48/60 ar 57 trim stage 3 wheel
dsm 450s
stock fuel system
2,5-3" dp
3" mandrell exhaust
2.5" charge pipes
10 psi 260 whp 270 tq
if it will help let me know, ill upload it
Old May 3, 2006 | 04:40 AM
  #88
Originally Posted by Dmc1
It would help me get a good start on a basemap for my 92 f22a1 setup is a 16g dsm turbo offf of an 04 evo
Uh, you only said 16G earlier.
That "16G" off the new Evo is good for 400+ whp. It's not like the earlier 16G... it is a MAN sized turbo.
Old May 3, 2006 | 06:04 AM
  #89
It would help me get a good start on a basemap for my 92 f22a1 setup is a 16g dsm turbo offf of an 04 evo an evo8 manifold dsm 550 injectors 1g crushed bov wiseco pistons
When I have a it done i will post up my bin to return the favor.
Ill get it on there in the next day or two!!
