Turbo not boosting
Old Jul 10, 2011 | 07:56 AM
im confused!!!! which megasquirt do u have because the megasquirt 2 has an internal 2.5 bar map sensor. tuning for exhaust temp isnt going to do u an good. to properly tune you need to tune based on engine load. you need to tune using tps, rpm, load(map sensor) and wideband o2.
Old Jul 10, 2011 | 02:35 PM
greco96's Avatar
i have the 2.5 and i am using tps.rpm map and wideband. But i know on others engines that the exhaust temps are used to give you a clue of what is happening in the cylinder. watching the temp can tell you if something is going wrong. I have not hooked up the sensors yet but the plan is to, not for tuning but for reference.
Donald125
May 18, 2007 11:23 PM
H22junkie
Apr 18, 2007 01:16 AM
AgentMurdoc
Nov 6, 2005 12:38 PM
DRAG_ON
May 20, 2004 09:41 AM
aron2063
Mar 14, 2003 11:56 PM
