my rt4wd wagon and my homemade turbo manifold
Old Jan 9, 2011 | 10:28 PM
Maloney's Avatar
Originally Posted by QwikKotaTx
Am I missing something? Are you going to cut a port and weld on the turbo flange to the manifold at a later time?
LOL exactly what was going through my head... im like wtf is this a joke?
Old Jan 16, 2011 | 01:14 PM
short_sir's Avatar
coming from a pipefitter this is not the best way to do this .. should have used carbon fittings sch80 minimum with a bevel.. then you could burn a root in with 6010 and fill with a 7018 rod..even when you welded the cast fittings you should have dremeled out the threads inside..and put a 37 degree bevel of some sort just to get some penetration.. here you have none and it WILL crack
Smith-02
Oct 28, 2007 03:08 PM
akiraboy
17
Oct 26, 2003 12:23 PM
turbowagonman
0
Jun 20, 2003 10:35 PM
