VW Beetle Turbo
Old Apr 27, 2010 | 03:27 PM
FAST65's Avatar
Default VW Beetle Turbo
hi from the UK i found this site whilst looking for info on Holset H1C turbos so here we go ive been working on thisat weekends since december got this from ebat for £200
brand new in the box never used so now ive got to make it fit a standard VW Bettle body, the engine is already a hi performace EFI engine 2332cc 205bhp
so here we start with the fabrification every part is made by myself in my garage at home.
making the exhaust manifold took 3 hours lol
charge cooler ebay again
inlet plenums
turbo lives here
turbo manifold
inlet manifold with the fuel and nos in injector
more to come
Old Apr 27, 2010 | 03:35 PM
FAST65's Avatar
engine stripped to lowere compression
back together
starting to come together now
charger cooler behind rear seat
EGT sensor
air filter was a pain to find a place but fitted here
charger cooler rad fitted here
engine up and running sound fails after a few seconds as it too loud lol
i had to fit a scavange pump as the turbo was passing oil so make a braket and fitted here
so heres the car
i would like about 350 bhp but we will see what happens so finger crossed i can get the car into the 11s
thanks for looking
cheers andy
File Type: jpg
Old Apr 27, 2010 | 03:39 PM
boosted-t's Avatar
great choice goin with the holset.you wont be disappointed with it
by the way,welcome to the forum
Old Apr 28, 2010 | 04:44 PM
sha-d's Avatar
cool build!!
though, your sound cuts out at 11 seconds
Old Apr 28, 2010 | 05:00 PM
FAST65's Avatar
Originally Posted by sha-d
cool build!!
cheers thanks guys,
yeah the engine was too loud for the mic i will do another
a few little items manufactured tonight in the garage, first of all was how was i going to fill the engine with oil, solution make this from an old dizzy and a breather from a Hydraulic tank looks good me thinks
second was a mount for the tach and the boost gauge poped to B&Q and had a look through there metal stock and made this
last of all fitted the electronic boost controller into the dash
thanks for looking cheers andy
Old May 6, 2010 | 03:53 PM
neilandbob's Avatar
Top man, you must have some ***** doing that to a Beetle engine. Get yourself down to RTTS, you'll be a God.
Old May 9, 2010 | 09:22 AM
FAST65's Avatar
cheers getting there now but still loads to do
thats the charge cooler header tank and pump i have also fitted a drain valve that goes through the boot floor so i can drain the ice water from it.
i have been thinking about the water injection tank i want to hide as much as i can so my thoughts are to cut the fuel tank in about a 1/4 of the way along and weld a bulkhead into it, weld it back up with a second filler neck for the water injection what do you think?
cheers andy
Old May 9, 2010 | 10:22 AM
sha-d's Avatar
we need more vids!! WITH SOUND!!
Old May 10, 2010 | 12:00 AM
boosted-t's Avatar
+1 i wouldnt mind seeing some more vids
Old May 11, 2010 | 04:56 PM
FAST65's Avatar
cheers guys more vids coming, cant start the car at home the locals are compalining bit more done
Right got home this afternoon and cut a hole on the tank (after eptying and washing out )
Welded in a bulk head, fitted a filler and also a leval switch
welded the the bottom on
doesnt look to bad :clap:
bit more work on the tank tmw clean all the old paint off bit of filling and paint and back in the car
another job done
thanks for looking
andy
