Large Oil Drain Flange Help
Old Aug 20, 2010 | 12:34 PM
ARAMP1's Avatar
Default Large Oil Drain Flange Help
I'm having trouble finding an oil drain flange large enough to fit my turbo. I don't know what type of turbo it is, other than it's a Garrett and I have a Detroit Diesel part number. (Pic is below) The flange dimensions are as follows. The drain hole is just over an inch in diameter and the mount bolt spacing is approximately 2.1 inches center to center. Any ideas where I could get something that would work? I've googled and yahooed and can't find anything. I think I might be able to find some half inch thick piece of aluminum and just drill it out to work.
Old Aug 22, 2010 | 07:06 AM
Garrett GT TURBO OIL DRAIN FLANGE ADAPTER 1/2" NPT: eBay Motors (item 130420058223 end time Sep-10-10 18:02:26 PDT)
Old Aug 22, 2010 | 09:40 AM
ARAMP1's Avatar
Too small. Does not fit.
Old Aug 23, 2010 | 12:50 PM
josh19wrc's Avatar
just out of curiosity, what turbine inlet does it have? Where did you get that beast?
Old Aug 23, 2010 | 02:46 PM
ARAMP1's Avatar
I'm new to turbos (this is my first turbo vehicle), so I'm not sure how the size is measured, but it's got A/R .75 M24 RC on the inlet and A/R .96 M1 G2 on the exhaust. I found it on e-bay. It's for a Detroit Diesel, which is what it's going on. (Although it's made for a 6 cylinder, it's going on a 4). Here's the setup so far.
Here's the truck that it's in. It's a 1990 Chevy Silverado.
Old Aug 23, 2010 | 07:33 PM
i have a 1/2 npt drain flange that measure 2.00 center bolt to center bolt. (measured with a dial caliper.)
Old Aug 23, 2010 | 08:30 PM
ARAMP1's Avatar
Yeah, I can find 2.0 inch pretty much everywhere. It won't fit to mine. Mine is 2.1 inch center bolt to center bolt. The drain hole is just over an inch in diameter.
Old Aug 23, 2010 | 09:44 PM
ARAMP1's Avatar
Here's a picture. It's 2.1"/53mm center to center. All the drain flanges I've seen are 2.0"/50.8mm center to center.
Old Aug 24, 2010 | 09:13 AM
you may have to make it or buy it from the mfg of the turbo or the mfg of the engine it came from.
Old Aug 24, 2010 | 12:36 PM
josh19wrc's Avatar
NICE RIG MAN!
