2 dump or not 2 dump...
Old Mar 1, 2007 | 11:56 AM
  #11
Jcushing's Avatar
Default Re: 2 dump or not 2 dump...
open dump will make more power if you have a restrictive exhaust/downpipe, then it cant handle the extra gas efficiency
just be carefull where you dump it since theres no oxygen in that gas, you could in theory suffocate your engine (more likely on a dyno but still applicable to real world since people often tune their car on a dyno) if you dump far enough away and have sufficient engine bay airflow.
Old Mar 1, 2007 | 08:13 PM
  #12
CspecRun's Avatar
I had planned on venting to the atmosphere, I just wanted to make sure that it wasn't goin' to cause any problems...I didn't know that dumpin' to the atmosphere could actually give you a lil bit of gain in hp...as far as sound goes, I enjoy scaring tha $hit out of old peple
Old Mar 1, 2007 | 09:42 PM
  #13
ChevyIIMan's Avatar
------- ricers
Old Mar 1, 2007 | 09:52 PM
  #14
Turblow's Avatar
Open dump makes mroe power
Open dump is easier to fab
Open dump is less expensive
Open dump sounds better
Open dump just makes more sence
Did you already guess my car is open dump and I wouldnt have it any other way? It sounds good
Old Mar 1, 2007 | 09:55 PM
  #15
greenbomber's Avatar
I'm have an open dump right now, i was cool at first, but it make my car sound like *** more then it allready does.
Old Mar 2, 2007 | 02:24 AM
  #16
2G6's Avatar
2G6
If you want to sound like a ------- John Deere tractor at WOT then vent it, if you want to have your turbo and bov be the dominant sounds then plumb it back into the exhaust. I ran an open wg on my Eclipse and it is so obnoxious. It's loud and sounds like you have a boosted Murray lawnmower under your hood, not to mention the black soot that accompanies dumping to the atmosphere. It's way better recirculated IMO.
Old Mar 2, 2007 | 02:26 AM
  #17
2G6's Avatar
2G6
BTW, open wastegate is sofaking 1999-2004, now it's just considered old school, at least around here.
Old Mar 2, 2007 | 02:27 AM
  #18
ososlohatch's Avatar
mine makes a pshhhhhhhhhhhhhhhhhhhhhhhh sound when it opens, some sound like disel tractors though..lol people use to think it was my turbo spooling so loud ..hahaha
Old Mar 2, 2007 | 02:54 AM
  #19
ChevyIIMan's Avatar
dumping to atmosphere is fine when your running high PSI but on low boosted applications it open real early, just sound like you have an exhaust leak...
Old Mar 2, 2007 | 05:27 AM
  #20
SpankedYA!'s Avatar
I think open sounds like ----. Here was mine.
