T04 Turbos READ ME!
Old Jan 11, 2005 | 12:11 AM
StealthBOY's Avatar
Default T04 Turbos READ ME!
I am looking for a turbo good for about 500/600 hp. Any one think a T04 with Compressor A/R of .60, Turbine A/R of 1.00 can do the job? Also, do you think this will be to laggy on a six cly engine? Also if you have any suggestions please post them as well.
Thank you in advance for replies
Paul
Old Jan 11, 2005 | 12:13 AM
87na_rx7's Avatar
Default Re:T04 Turbos READ ME!
thats a huge turbo, i was talking to a guy with a turbo v8 that had a .90hot side and he said it spooled shitty
Old Jan 11, 2005 | 12:20 AM
Cadracer's Avatar
i have a t04 on my 350 an it has a .70 exhaust side an it spools about 2600 an full boost i say hits about 4000 or so im busy driving it to look at the boost gauge so i dont know from there.A 6cyl would have to turn 8k to spool it with that ar. Also it would be laggy on a sb engine even a lil slow on a big cube engine.the one that i have found that spool good with the small blocks is the .68 ar t3.
So i guess a t3/t4 with like a .63/.70 would work well
Love to try out a ball bearing turbo just to see what the difference it would make.Thats just my 2cents worth
Old Jan 11, 2005 | 12:24 AM
StealthBOY's Avatar
This will be run on a 2jzGE motor, I'd love to buy a huge turbo like a T04R but I will never spend 2000 dollars on a turbocharger. Most guys opt for the t66/t72 and hit full boost at about 4500 rpm, still think it wont spool fast enough? (no sarcasm intended). I dont care if boost does not kick in until 4500 rpm
Old Jan 11, 2005 | 09:01 AM
StealthBOY's Avatar
TTT?
D16Y7-T's Avatar
Do a ball bearing T72. Spools fairly quick and I think you can even get them with ceramic fins which rediculously quicker then conventional fins.
Old Jan 11, 2005 | 02:45 PM
Reddy's Avatar
we put a 1.32 turbine on a Taurus with a .70 compressor and it spools fast as ----.
https://www.homemadeturbo.com/forum/...threadid=16774
TunerToys
Oct 1, 2007 12:20 PM
Brianin302
Aug 19, 2004 07:09 PM
Alex in Houston
Mar 20, 2004 11:26 AM
unfcknblyvbl
Dec 22, 2002 09:42 PM
