Old Aug 20, 2008 | 02:59 AM
josh19wrc's Avatar
Default Power Wagon Rebuild (Update: 11/5/08)
IVe had my truck for 10 years, the last 4 of which, its been parked, due to needing a complete restore. Well, school is finally ------- over, and I have a house, with a garage, so, this is my project:
360 V8, NP435 tranny, NP205 gear drive case, Dana 60's, 34" tires, 8K lb, PTO drive winch.
When Im done, its gonna be packin the same driveline, only with 42" tires, and I've got an idea up my sleeve to make it AWD, only it will be selectable, and it will be true AWD, with a high and low range.
Of course,
The goal is 650+.
Old Aug 20, 2008 | 05:24 AM
turbo4life's Avatar
Default Re: my "new" project
oOOO la la i like this twin turbo.. will it be a SEXY BLOW THROW CARB
Old Aug 20, 2008 | 08:00 AM
bigdaddyvtec's Avatar
Small block Mopar... What flavor
Old Aug 20, 2008 | 10:33 AM
josh19wrc's Avatar
1983 360. LA series, not the magnum.
Old Aug 20, 2008 | 11:47 AM
Birdley42008's Avatar
That beast screams,
"Get the ---- out of my way!"
I vote gunmetal stacks!
Old Aug 20, 2008 | 05:34 PM
Atticus's Avatar
Originally Posted by Birdley42008
That beast screams,
x2
fucken eh man
you going FI or carb?
Old Aug 20, 2008 | 08:17 PM
mopar318's Avatar
I like how you put the two pictures side by side to make it twin turboed.
What are you doing to the engine? A 360 is not going to spool those two turbos very quick.
Old Aug 20, 2008 | 10:57 PM
josh19wrc's Avatar
it will be a crack on the laggy side, but, when they power up, all hell will break loose I want it a touch laggy, as 6500 static lbs on one end, and an instantaneous 500+ HP on the other would result in lots of broken ----. At least if it is a bit laggy, the truck will be moving before the twins strut their stuff.
Carb all the way... old school.
Old Aug 21, 2008 | 12:48 AM
con's Avatar
con
I love it very very much but ---- the awd, it would be a giant waste of time that would end in fail.
Old Aug 21, 2008 | 03:17 AM
josh19wrc's Avatar
*** end walks all over right now as it is in 2wd, as 70% of that 6500 lbs is on the nose... with a twin turbo mill, AWD is gonna be required, not optional...
