Go Back   HomemadeTurbo - DIY Turbo Forum > Homemadeturbo > Forced Induction
Old 08-01-2007, 04:47 PM   #1
malibutwinturbo
Default quick question...
altho i think i already know the answer, is there anyway to set the boost setting lower then the factory preset on the turbo...??
prolly noob question, but i don't care
malibutwinturbo is offline   Reply With Quote
Old 08-01-2007, 05:02 PM   #2
sikcrx89
Default Re: quick question...
you could do the ole' adjustable rod trick or a carb spring to help you adjust factory internal wastegates
sikcrx89 is offline   Reply With Quote
Old 08-01-2007, 05:10 PM   #3
malibutwinturbo
Quote:
i know about the rod trick...tho i dunno if i really want to try it...maybe as a last resort
& whats this carb spring trick? is it simple? sounds like i got to bust open the diaphram housing....
Old 08-01-2007, 05:17 PM   #4
sikcrx89
http://www.homemadeturbo.com/forum/i...6395.msg909685
shows and example of the adj. rod and him cutting the gate open and putting a different spring in it..
or just get an exaternal one.. it would be easier
Old 08-01-2007, 06:53 PM   #5
malibutwinturbo
the reasons i'm not going external is;
-cost (gonna need 2)
-complexity (piping, etc)
i'm trying to stay simple & clean
i guess i'll have to go experiment in the garage
thanks for the link
Old 08-01-2007, 06:55 PM   #6
Zeniceguycrx
get a deal from donald for 2
open dump tubes are easy to make
Zeniceguycrx is offline   Reply With Quote
Old 08-01-2007, 07:04 PM   #7
ososlohatch
Quote:
now your talkin, dont forget about beer when your out there it helps
ososlohatch is offline   Reply With Quote
Old 08-01-2007, 09:27 PM   #8
malibutwinturbo
that reminds me...i need to get another 30-pack of cold ones
Old 08-01-2007, 11:50 PM   #9
E-b0la
dirty 30 FTW.
E-b0la is offline   Reply With Quote
Old 08-02-2007, 11:24 AM   #10
malibutwinturbo
haha, i must be losing my mind, i went to tinker with the turbos today, & the rods are already threaded from the factory, funny i don't remember seeing that, but hell, it must be over a year since i last looked at these up close
tho i don't think they'll get low enough, i wanna start out at like 4psi
- by chenzob
- by CreeK
