Go Back   HomemadeTurbo - DIY Turbo Forum > Homemadeturbo > Hybrid/Tech
Old 01-23-2007, 09:59 AM   #1
Guy-Fast
Default B Series Intake Manifolds The Real Deal
Well here is a little list with pics and info regarding b series factory intake manifolds
Here we begin with the baller B manifold the B18c1 or GSR. This is a 3 piece manifold and is by far the best flowing B manifold when ported correctly. Lots of work to achieve this and a flowbench rookie's with a dremel tool send it off to a pro. Only gsr manifolds fit on gsr heads
Now we move onto the wonderful world of The Integra LS Non Vtec world. From 1990-2001 the LS is the easiest and cheapest B series motor to find. There are some major differences in these manifolds
Starting with the b18a1 the 5 spd and Auto have a different manifold but same bolt pattern. The Automatic has an egr port not found on the 5 spd b18a1 manifolds notice egr port on 1st pic
5spd b18a1
JDM b18b1 Manifold. This uses a different IACV from the b18a1 along with different fuel rail. All b18 non vtec ls manifolds fit on ls heads and only ls heads
Oh so popular B16a Manifold. There are also minor changes in the b16a from 1989-2000 from IAT change found in OBD2 along with vacuum ports in different areas. Also different fuel rails. Plenum volume also changes between the years but nothing to fuss abou. Again only b16a manifolds fit on b16a heads
obdo jdm b16a manifold
obd1 jdm b16a manifold
Finally we get to the oh so famous ITR manifold. Large plenum volume 1 piece manifold. Fits b16a and ITR heads only. 64mm factory plenum. Great manifold. Requires obd1+b fuel rail.
Thats it just some good ole info. Enjoy
Guy-Fast is offline   Reply With Quote
Old 01-23-2007, 10:08 AM   #2
Guy-Fast
Default Re: B Series Intake Manifolds The Real Deal
Old 01-23-2007, 10:11 AM   #3
whiterice
Don't forget about the B20B giraffe:
or the 2-piece B20Z:
http://hybrid.honda-perf.org/tech/b20/b20tech.html
whiterice is offline   Reply With Quote
Old 01-23-2007, 10:12 AM   #4
Guy-Fast
Oh ya feel free to add to the thread but correct info. Oh the tall b20 manifold and 56mm tb odd stuff. Thanks whiterice good stuff. Hybrid still rules.
Old 01-23-2007, 11:16 AM   #5
D15Bastard
Make: honda
Year: 1990
good info
D15Bastard is offline   Reply With Quote
Old 01-23-2007, 01:10 PM   #6
whiterice
There's also the CTR B16B intake manifold which uses the same P73 casting as the ITR manifold. The CTR has a smaller throttle body and slight difference in a vacuum reference.
P73 casting:
CTR:
ITR:
CTR has the PCT stamp.
ITR has the P73 stamp.
See the nipple.
CTR :
ITR:
__________________
Elephant top mount turbo manifold
Sink Trap top mount
MBC w/ wastegate top port
Old 01-25-2007, 01:24 PM   #7
whiterice
Need to update these lines.
Don't forget about the B17A1 manifold from the 92-93 GSR.
Even though it's OBD-1, it is pretty much the same as the OBD-0 B16 cast with some slight differences.
intake swaps
Quote:
b18a=b18b=b20b=b20z
b16a=b16b=b18c5=b17a
b18c1 stands alone
How about a list of part numbers for the intakes?
92-93 B17A1:17101-P61-A00
94-95 B18C1:17100-P72-000 (part A)
17110-P72-010 (part B)
96-01 B18C1:17100-P72-A00 (part A)
17110-P72-A00 (part B)
94-95 B16A3:17100-P30-G00
96-97 B16A2:17100-P30-A00
99-00 B16A2:17100-P2T-A00
__________________
Sink Trap top mount
Old 01-25-2007, 07:35 PM   #8
Guy-Fast
Obd1 GSR b17a usdm is almost identical has the obdo JDM b16a minus the shorter IACV port. Same tb.
Old 02-04-2007, 12:11 AM   #9
MikeJ-2009
I'd sure like to see the finished product on a correctly ported gsr manifold. I started mine, and then threw it on the shelf because the ribs of the runners on the head side of the break looked impossible to do what I thought I was supposed to.
MikeJ-2009 is offline   Reply With Quote
Old 02-04-2007, 07:21 PM   #10
Guy-Fast
I did one of these awhile ago and it makes great power same work ericks racing and dhracing do also. Basically better like to spend around 15 hours on it.
- by chenzob
- by CreeK
