homemade Sportscar,with a turbo.
Old Jan 20, 2007 | 02:14 PM
#Rotor's Avatar
Default homemade Sportscar,with a turbo.
OK so it's the same as all the others I've built, so nothing new about it, other than that it's ... well a new un-used manifold... actually it's not done yet.... so it's better than new.
just that I've not posted for a while, so here goes.
It's on the SR20-DET motor in the Neo1 I'm designing and building.
Old Jan 20, 2007 | 02:27 PM
shadetree's Avatar
Default Re: New Turbo Manifold
That Diahatsu is crazy! Good work.
p.s. you can't see the large size pics of the mani unless you are sr20forum member.
Old Jan 20, 2007 | 02:53 PM
#Rotor's Avatar
ooops sorry ... did not know that.... let's see if the big pictures will show if i go like this...
Old Jan 20, 2007 | 02:58 PM
whiterice's Avatar
looks great. what is this project car? I see it's rear engine mounted. I also notice the threaded piping sections added on. Are you going to run coolant through part of the cage?
Old Jan 20, 2007 | 03:13 PM
#Rotor's Avatar
yes, those are the tubes running the coolant to the front mounted radiator.
here is what it looks like so far...
Old Jan 20, 2007 | 03:49 PM
ososlohatch's Avatar
sweet
Old Jan 20, 2007 | 03:56 PM
whiterice's Avatar
that looks awesome! sweet garage project. HMT ATOM
did you have someone else bend the sides and front dash bar?
Old Jan 20, 2007 | 04:03 PM
#Rotor's Avatar
yes, It's loosly based on the Atom's looks, but is completely re-designed. I designed the frame in Auto-Cad, then had it all Laser cut to size, the bent tubes also got CNC'ed by a company near by.
Old Jan 20, 2007 | 09:21 PM
BirdmanMD's Avatar
dude, theres no way thats going to work...you definetely need all 4 exhaust tubes going to the turbo.....
idiot.....
Old Jan 20, 2007 | 10:58 PM
#Rotor's Avatar
Oh... crap, something did look a little odd there for a while......... then again, i'm a lazy ***, I'm a NOOB, and it's my car, I can build it like I want it....
besides I'm only going to be using those 2 pistons, the other two is going along just for ***** and giggles...
