Willem programing problem
Old 04-11-2006, 09:05 AM
bozo's Avatar
Default Willem programing problem
I have willem chip programer. I am using 29c256 chip and every time I try to program the base map for my P28 i get a cel.
The willem software sais it is programed corectly and i have a green light like every thing is ok but the chip does not work in P28.
Does any one know how do I set up the programing speed and any other parameters for 29c256?
bozo is offline
Old 04-12-2006, 01:54 AM
bozo's Avatar
Default Re: Willem programing problem
Originally Posted by jagojon3
You don't need to change speed or anything, just select the 29c256 chip from the menu and it will be set up for burning that chip correctly.
Are you sure it's not your ecu (chipping job perhaps) that's the problem? Have you tried another chip? Either of these could give you a solid CEL.
Yes I select the 29c256 and the program selects its own parameters but the chip does not work. The willem program writes that chip is programed OK. Maybe I am making some thing wrong with uberdata 1.7. I selected stock gsr map and inserted P28. I deactivate O2 heater because my car does not have it and saved the bin. Later i programed that bin but it does not work. I also tried some bin files from the forums that other people made just to see if it will work, and it does not. I have 2 chips and they are new.
My P28 is OK because a frend of mine has the chip that works and I tried his chip in my P28 and it works.
When I activate willem eprom it opens information window and i writes:
PCB3/A/B SETTING JUMPER
WILLEM PCB short ZIF32 Pin3(-) Pin31
Does any one know what that means?
bozo is offline
Old 04-12-2006, 10:50 AM
95RedEX's Avatar
Your post is kind of confusing...
So you say your ECU is good because you can use some elses chip from a burner that's not yours. Your car starts, runs, etc. without a CEL. That would rule out your ECU, correct?
Uberdata could be a problem, but since you download different bins and burn them directly to a chip (never opening and saving them in any version of Uberdata first?), I would rule this out as well.
The burner says it is burning a chip correctly. Are you using the Willem setting or the PCB3 setting? What software version are you using? I would look into the burner setup more to figure out if you're doing it right. When you insert the chip, make sure you can ID it and it wouldn't hurt to verify afterwards.
The pop-up messages you're getting is normal. Some people have to use a wire jumper from 3 to 31 to get it to work right. My burner works with the PCB3 setting and I don't have to do it.
95RedEX is offline
Old 04-12-2006, 10:51 AM
95RedEX's Avatar
Make sure you're putting the chip in the burner and ECU right... They can go in backwards. :1
95RedEX is offline
Old 04-12-2006, 11:53 AM
bumblezc's Avatar
I love Moates!
bumblezc is offline
Old 04-13-2006, 03:31 PM
ifly87's Avatar
Which Wilem do you have? is it the enhanced or the dual power?
ifly87 is offline
Old 04-13-2006, 05:22 PM
bozo's Avatar
So you say your ECU is good because you can use some elses chip from a burner that's not yours. Your car starts, runs, etc. without a CEL. That would rule out your ECU, correct? Yes. Some tuner from Slovenia tuned frends chip and that ashol will not share his knowledge.
The burner says it is burning a chip correctly. Are you using the Willem setting or the PCB3 setting? What software version are you using? I would look into the burner setup more to figure out if you're doing it right. When you insert the chip, make sure you can ID it and it wouldn't hurt to verify afterwards.I inserted the chip corectli. I am shure because i pay atention to that. The willem i use is PCB4.5C AND the software that i use is lnstall Version 0.98D5( PBC45C [0.98D5] New!!) ***PCB35-98D5.exe ** (Update 13 September 2005) THAT IS PASTE FROM willem instalation cd.
The pop-up messages you're getting is normal. Some people have to use a wire jumper from 3 to 31 to get it to work right. My burner works with the PCB3 setting and I don't have to do it. Yes i solved this problem.
I still get a cel and a 3500rpm limit when i butn the chip. The willem reads the chip. ID is recognized and every fuc... thing is OK. The chip is burned OK but it does not work.
Maybe I did not understand Uberdata wery good. I open the uber, i open the stock gsr and than insert p28 map. After that i set up fuel and ignition and some other things and save the file. After that i burn it to the chip. IS THAT the way to make the bin file and tune or I am doing it all wrong?
bozo is offline
Old 04-15-2006, 10:26 AM
95RedEX's Avatar
You might've read this already, but this might help:
http://home.mn.rr.com/keebler65/honda/tuning.html
Also, check the CEL if you can. The 3,500 rev limit is probably limp mode.
95RedEX is offline
Old 04-17-2006, 05:01 PM
bozo's Avatar
I have solid cel. I tried uber and crome and I am not shure if my maps are ok.
I open the uber, open the stock gsr map, then inster p28 and I remove the o2 heater because my car does not have it. I save the map as it is. Is that stock p28 map or I am doing it all wrong.
In the crome i just open the p28 map and make smal changes because I have 1.5 and save it.
Would that bin be ok or I am doing it all wrong
bozo is offline
Quick Reply: Willem programing problem
