92 mustang twin turbos
Old Aug 21, 2005 | 01:25 PM
linkmustang's Avatar
Default 92 mustang twin turbos
92 5.0 fox body mustang twin turbos
the setup is all stock mustang
Exhaust System, American Thunder, Cat Back, Aluminized Steel, Ford Mustang, Kit, also battery relocation
the turbos are
pair of 50 trim Garrett T3 turbochargers. These turbos feature .42 ar compressor housings and .48 turbine housings with internal wastegates and 2.25" swing valve addemblies.
i will be useing the intenl wastegates
turbo parts i got are
new bosch 1.8t BOV
it will hold 12-14 psi
for 10$
flanges
the one with the 8 holes the holes on the out side are for chlalsr turbos
Old Aug 21, 2005 | 01:31 PM
Default Re: 92 mustang twin turbos
so others are i redid one of the turbos. i did the drivers side with a t birb ex scroll so it mounts right
other parts i got are
bought 8 42 pound injecters of ebay for 240$
udate bought 76mm C&L mass air flow air meter sensor. This meter is calibrated for 42 pound injectors using C&L's sampling tube. ebay 76$
update Walbro 255 LPH Part # GSS340
ebay 96
Holley Adjustable Fuel Injection Regulator
Old Aug 21, 2005 | 01:34 PM
some more
parts
part that swrew into the guage then the shrader vaulve
ball flanges
Old Aug 21, 2005 | 01:37 PM
installed my a/c elim delete kit
Old Aug 21, 2005 | 01:41 PM
ok here the turbos mounted where i wont them
this is the passengers side
where the ex exits the turbo
Old Aug 21, 2005 | 01:44 PM
also mounted turbo on drivers side
i hope i will be ok on the sway bar
does the sway bar move alot?
Old Aug 21, 2005 | 02:45 PM
i dont know i have the code up dome where eles so i was easy
Old Aug 21, 2005 | 03:08 PM
Reddy's Avatar
Seriously are you actually retarted, didn't make it to high school or just foreign?
