dont listen to the guy who just posted, *cough*moron*cough* yes your a6 dizzy will work you will have to notch or drill the top mount of your dizzy to make it a little wider to be able to bolt into place, everything else will work all the same. just use your obd0 intake manifold/tb/sensors.
hay zc er u ---- up pice of ----
read what i said iam telling him it the foot patterns dont line up. if u are going to use that dizz your not going to noch it. your going to have to cut it off the foot all the way. so no it wont work if u dont want to mod it and yes if u do. but if the crank angle sences is in the dizz of a6 than u will get a code because the crank angle sences of the y7 block wont hook up right.
