Go Back   HomemadeTurbo - DIY Turbo Forum > Homemadeturbo > Hybrid/Tech
Old 03-06-2005, 01:14 AM   #1
crx304
Total Props: -1
Default Filling Block... How To.... UPDATED
ok, so this is basically common sense but here is a how to on what i did.
things that you need:
- stripped block of your choice
- epsom salt
- devcon liquid aluminum www.grainger.com ($45)
step 1:
make sure block is level (use a level on the deck)
step 2:
look to see that H2O drain plug is still in block, but loose
step 3:
w/ h20 pump removed, duct-tape up where the H2O pump was
step 4:
pour salt evenly into the H20 jacket
step 5:
take a screwdriver and find height just abovethe H2O pump hole and mark it on the screwdriver
step 6:
take screwdriver around jacket at predetermaned height to make the salt even
step 7:
mix proper ammount of devcon liquid aluminum about 3/4lb
step 8:
pour slowly (leaving approx 3/16" from deck) ***take finger and run around jacket removing excess... works well***
step 9:
let cure at room temp for 2 hours and the at 200* for 4 hours. what i did was put the block over a heat vent and shut the rest in the house. so it was basically F.I. even before it was in the car then after 4 hrs w/ heat, let stand @ room temp for 18 hrs
step 10:
pull drain plug after 24 hours (full cure time) and run water thru it to remove salt (at least 5 minutes) remember to spray WD40 in bores after H20
step 11:
put "new" gasket on top of block and mark it w/ a sharpie where the coolant holes go
step 12:
use a undersized drill (1/8") to make a "pilot hole" and on the slots, drill 2 holes for the outside radai of each slot
step 13:
goto larger sized drill and open up the holes, and slots
step 14:
blow out block after drilling then rinse w/ H20, respray WD40 in bores
step 15:
macine work, have it honed or bored or whatever
step 16:
rebuild
now, here's the thing....
i want to dispell the myth about the overheating issue....
if done right, you will have no problems at all.
i have drove my car for 100 miles so far w/ no T-stat and the gauge hasn't went above C. i also can just barely feel any heat comming out of the vents. so if worse come to worse, and you are getting hot w/ the T-stat installed, remove it and you will see a temp drop.
good luck!
mike
__________________
<br />MY BEAST:&nbsp; http://www.homemadeturbo.com/forum/index.php?board=1;action=display;threadid=24733<br />http://members.cardomain.com/crx304
crx304 is offline   Reply With Quote
Old 03-06-2005, 08:02 AM   #2
SpankedYA!
Default Re: Filling Block..... How To
Nice write up. I may try it now!
SpankedYA! is offline   Reply With Quote
Old 03-06-2005, 11:48 AM   #3
absolutezroo
i'm gonna use the block filler that summit racing sells...is it basically the same stuff?? i know it's a few buck cheaper so i didn't know if there's much of a difference in contents
absolutezroo is offline   Reply With Quote
Old 03-06-2005, 11:49 AM   #4
SpankedYA!
Absolute post up a link for that please.
Old 03-06-2005, 11:54 AM   #5
absolutezroo
http://store.summitracing.com/defaul...=egnsearch.asp
it ends up costing about 21 bucks because of hazardous shipping
Old 03-06-2005, 12:13 PM   #6
nonvtec
Driving without a T-stat is bad, that isn't an option. Good write-up, I have thought about this a lot.
nonvtec is offline   Reply With Quote
Old 03-06-2005, 12:27 PM   #7
absolutezroo
can't you just get a t-stat that opens at a cooler temp?
Old 03-06-2005, 09:18 PM   #8
Foowee
What is snow salt? and where do I get it?- is it the same as rock salt you use on your driveway in the winter?
Foowee is offline   Reply With Quote
Old 03-06-2005, 10:17 PM   #9
themadhatter
Total Props: 1
yes rock salt is snow salt
themadhatter is offline   Reply With Quote
Old 03-06-2005, 11:22 PM   #10
CIVIC.93
this is gonna sound dumb but how do you get the salt to stay in block?
CIVIC.93 is offline   Reply With Quote
- by chenzob
- by CreeK
