ball bearing turbo oil supply
Old May 15, 2012 | 06:31 PM
Roadrunner's Avatar
Default ball bearing turbo oil supply
The turbo diesel engine in my car has had an aftermarket ball bearing turbo installed, the original turbo had the standard brass bearings floating on oil, my question is how much should I reduce the oil supply to this ball bearing turbo? I have no figures for the standard turbo's oil supply pressure and flow. How would the oil supply to the turbo be restricted, and where would I put in a re stricter to slow the flow/pressure?
Old May 15, 2012 | 07:36 PM
rohmer's Avatar
a garrett ball bearing turbo likes to see around 40-45 psi. just to give you an idea.
Old May 16, 2012 | 08:12 AM
most ball bearing turbo applications use a 0.035-0.040" restrictor orifice in the feed.
Old May 16, 2012 | 06:07 PM
Roadrunner's Avatar
Thanks for the replies, I will hunt around for a restrictor !
Old May 16, 2012 | 10:49 PM
rohmer's Avatar
put the restrictor as close to the turbo as possible. this makes it easier to check.
+1 on a .035 restrictor.. should do the trick.
Old May 17, 2012 | 02:37 AM
Roadrunner's Avatar
I'm not up to date with turbo lingo...what does "+1 on a .035 restrictor " mean exactly?
Old May 17, 2012 | 03:47 AM
ek4's Avatar
ek4
think the + 1 would be him agreeing with the restrictor idea and the .035 the size
Old May 17, 2012 | 12:17 PM
rohmer's Avatar
exactly. also note: that restrictors have also been called "pills" so don't be confused. you can usually put a restrictor the point where the oil line connects up to to the turbo. do this instead of putting the restrictor at the point where the oil line leaves the engine block. hope that clears things up a bit.
Old May 17, 2012 | 05:30 PM
Roadrunner's Avatar
Thanks a heap! virtual beers for all!!
Old May 19, 2012 | 07:34 AM
ghettoturbo's Avatar
...might want to talk to the turbo manufacturer before you do anything. Some already have a restrictor built in and cutting oil flow more could cause damage.
-Jay
