obd0 to 0bd1 problem
Old Apr 4, 2012 | 03:32 AM
AFTeg's Avatar
Default obd0 to 0bd1 problem
I am running a p30 tuned for boost. I swapped in an obd1 dizzy and connected the harnesses. I have double checked all the connections to make sure they are correct and from what I see they are. I connect my ecu through ecucontrol. As soon as i connect and push start logging the MPH will jump to 116. The map reads good. I try to start the car and it will go to start and then die. If i hit the gas I can keep it running. I pulled out of the drive way and drove it down the road and went into limp mode. I may have missed a wire somewhere when going over the harness. But Im getting second opinions right now.
turboD16crx
14
Jul 11, 2006 06:28 PM
91efate
6
Apr 17, 2006 10:27 PM
ibby
Nov 11, 2004 04:36 PM
4g63colt
May 24, 2004 09:58 PM
LittleG344
Feb 23, 2003 06:13 PM
