Boosted F22B5 Accord Coupe
Old Mar 28, 2012 | 04:37 PM
accordcoupe's Avatar
Default Boosted F22B5 Accord Coupe
Hi all, im after a bit of information if anyone can help, i have got a 1996 f22b5 accord coupe and i am in the process of charging it, i have got a chipped p06 ecu, a t04e turbo with external wastegate, all charge pipes and bov, the car starts and runs currently on a base map, i have been told different stories regarding needing bigger injectors and bigger fuel pump, i have a5.8 psi wastegate spring and dont intend to run a boost controller as have no intensions to run much boost to be honest. its running stock internals. Any help would be appriciated, Cheers Dan
Old Apr 18, 2012 | 07:39 AM
egh22ahatch's Avatar
Get urself some DSM injectors u should already have the resister box so ur good there stock fuel pump should hold up soo just spend ur money on the best tune u can afford that's one thing I beleave u just can't cheap out on
Xgenturbo
Jul 4, 2007 12:23 AM
MyVtec8yourV8
May 8, 2006 01:43 AM
shmaptoe
Apr 22, 2005 05:43 PM
osf
Dec 5, 2003 04:57 PM
