Is this ok for a collector?
Old Nov 1, 2011 | 12:16 PM
Elliott19864's Avatar
Default Is this ok for a collector?
I know it needs tidying up, this is just a practice, but is the general idea ok?
Attached Thumbnails Is this ok for a collector?-606198c6.jpg   Is this ok for a collector?-b0a5ac13.jpg   Is this ok for a collector?-1ad55f49.jpg
Old Nov 1, 2011 | 05:24 PM
hoochhenry's Avatar
not bad what are you cutting them with ,did you make up a jig ?
Old Nov 1, 2011 | 05:28 PM
Just a cutting wheel/grinder and shaping with the grinder and probably a die grinder when I get one.
Didnt make a jig.
Old Nov 4, 2011 | 08:33 AM
pretty good job for using a grinder and a cutting wheel. a mig welder will fill the gaps rather easily. best most affordable tool to do this would be a chop saw with a jig. i went a step ahead and purchased a cold saw but of course its not needed.
Old Nov 4, 2011 | 12:08 PM
Thanks. I have done a bit of research since and made a jig for my chopsaw, going to practice with some PVC this weekend with different angles.
W O T
Oct 21, 2004 11:42 AM
eightvalver
Apr 27, 2004 07:44 PM
