Ball bearing questions
Old Jul 25, 2011 | 05:41 AM
bbbrad's Avatar
Default Ball bearing questions
Hi, new here. Im wanting to know if you can buy the fancy ceramic bearing that are used in turbos. I found quite alot of ceramic bearings but nothing that can handle 200000rpms.I know that companies like aerocharger have been running ceramic bearings for years, so I would think they're not super fancy or new?
Old May 22, 2012 | 09:42 AM
MetricMuscle's Avatar
THREAD REVIVAL!
It may just be a question of keeping the bearing small, less diameter so centrifugal forces are less. Do they actually rate ball bearings in RPM capacity?
.....which leads me to my reason for reviving this thread. Has anyone made a ceramic ball bearing assembly that would press into a bored CHRA?
-Make a sleeve say out of steel pipe.
-Press ceramic ball bearings and shaft into sleeve and then press assembly into a CHRA that has been bored to accept this sleeve.
-Viola! My TD05 is now a triple ceramic ball bearing turbo.
Old May 24, 2012 | 06:35 AM
Caroline Willison's Avatar
Hello,
Aerocharge are really superb into their work since from years, u can buy a fancy bearings from them.
Old Jun 23, 2012 | 05:20 PM
Emperor's Avatar
Originally Posted by MetricMuscle
THREAD REVIVAL!
funny....i was thinking EXACT the same today when i was stand in front of my car with a busted RB25 T3.....why not drill the ---- out of it and press new bearings in?
Old Jun 23, 2012 | 05:30 PM
I've looked at how Comp Turbo does theirs, pretty slick approach, loose tolerances for heat consideration, grease as a heat sink. Cooling the shaft is currently the obstacle I'm thinking about. Without oil flow thru the CHRA the shaft will be spinning in the open without anything to carry the heat it is getting in the turbine away.
Another company, AR I think, still uses pressurized engine oil but to lube the bearings lightly as well as cool the shaft. They just use two bearings instead of CompTurbo's three.
typer
Oct 30, 2004 02:47 AM
Platty9
Jun 18, 2004 09:23 AM
d16tuner
Nov 28, 2003 04:25 PM
CivicDragon916
Aug 24, 2003 02:53 AM
turbocivic17m
Jul 17, 2003 05:11 PM
