tuner who uses eCtune or Neptune in nashville?
Old Jul 2, 2011 | 03:21 PM
burntmushu's Avatar
Default tuner who uses eCtune or Neptune in nashville?
does anyone know of a tuner in nashville area who uses Neptune or eCtune to tune ur cars? I know a guy who uses crome but all the guys at the other forums say it's not reliable enough. is this true? if so need to find someone who can tune my car. i have a chipped ecu that will need to be remapped.
previous build:
chipped ecu tuned with crome
stock h23
255lph walbro
440cc injectors
dsm 16g turbo
new build:
darton dry flanged sleeve 87.5mm, cp pistons, crower rods, clevite bearing, balanced shaft
crower stage 2 cams, crower springs, si stainless valves, pnp head
12lbs f1 flywheel, act 6puck unsprung clutch disc, hd pressure plate
1000cc evo injectors, aem fuel rail, aem fpr, 255lph walbro fuel pump
garrett 60-1 t4 turbo
3" full exhaust kit from kteller
so i know this is going to change tons so i would like a more reliable tune if crome is not stable.
Old Jul 7, 2011 | 05:23 AM
brettsb16a2's Avatar
What forum says Crome isnt reliable, they are idiots, i have been using crome for 3 years and i just keep getting faster. There is only two forums that have the best information on honda's, this one and www.pgmfi.org Picture this, b16a2 all stock internals, 11 psi, daily driver, 25,000 miles since turbo install. Now with such a high compression engine, dont you think i would have destroyed it already if crome wasn't reliable, it does exactly as i tell it.
Old Apr 28, 2012 | 02:57 PM
burntmushu's Avatar
so anyone know of anyone who's got a dyno and reputable who can dyno tune my car around my area? to be exact i live in ft. campbell. 1hr north of nashville.
burntmushu
New Member Introductions
0
Jul 2, 2011 03:11 PM
alexg103
May 6, 2009 10:50 AM
Inquisition
Mar 11, 2008 07:23 PM
hdcuellar
11
Mar 2, 2008 11:36 AM
emoretared
Jun 22, 2007 04:20 PM
