Doing a blow through setup. Looking for a fuel pressure regulator. Read that a oem honda regulator is 1:1 would this work? Ive done many turbo setups just this is my first blow through. What do you guys recomend for a regulator that is reasonable.
you need a fuel pressure regulator designed for low psi for carbs. a fuel injection fuel pressure regulator will not work. aeromotive makes them in 1:1 boost refernece ratio.
