Go Back   HomemadeTurbo - DIY Turbo Forum > Homemadeturbo > Engine Management
Old 07-16-2010, 03:49 PM   #1
tamer fahmi
Make: seat
Year: 1979
Default 2 ecms and i cps
hey there guys,
is it possible to run 2 separate engine control modules though the same crank position sensor..that is, can the signal be divided into 2
tamer fahmi is offline   Reply With Quote
Sponsored Links - Subscribe to remove this ad.
Old 07-20-2010, 08:34 AM   #2
coxy
Make: Subaru
Year: 1989
Should work OK just need to use diodes to make sure the ECU's dont crosstalk.
coxy is offline   Reply With Quote
- by mspNICK
Copyright © 2009 Homemadeturbo.comAd Management by RedTyger
