Quote:
Originally Posted by busa4
hardest part will be finding/fabricating a turbo manifold.
lol. 150hp above stock is a lot of power and will most likely kill your stock motor.
for every 1psi boost you will make ~10 more hp. a safe amount of boost on a stock engine is 8psi or less. this is just a general rule of thumb. some engine can take more or less but for the most part 8psi is a good number most people run reliably
with th 4.0L jeeps you dont need a manifold. just modify the exhaust pipe where it wraps around the front of the motor and bring the pipe up to the top of you engine bay on the pass side. If you want to se how its done look at this web site.
505 Performance I have a 97 wrangler that i turboed based off thier system and the only thing I had to do was buy the piggy back computer from Split Second because I was pushing more than 8lbs of boost. when I was running I was running a stock turbo from an eclipse gsx I never needed to modify the fuel progaming. I only needed to use the piggy back after i changed turbos and got in the higher boost levels, stock HP on the 4.0L avg is about 175 with a T3T4 turbo boosting 22 lbs I dynoed in 3rd gear at 4800rpm - 310 HP @330 ftbs torque, on all stock motor, the only mods were the fuel injectors and piggy back computer. I also did a dyno pull with 100 shot of NOS, same gear and rpm and ran 377HP @ 344 Torque
What year is your jeep? and do you know what country it was built in? Here is a pic of my wrangler.
