... turbo manifold, is the ZC a B or D series?
Old May 3, 2010 | 10:31 PM
devonb456's Avatar
Default ... turbo manifold: is the ZC a B or D series? AND...
im basically taking a poll because some people say its b and some people say its d because of it s simularity to the d16A1. I would like to know what manifold to install. Thanks guys!!!!
Also, I may want to do a DIY turbo setup on my dohc ZC. From your knowledge, what is the most cost effecient and reliable setup i should do? Thank You very much for your time!
Old May 4, 2010 | 12:32 AM
devonb456's Avatar
found it to be D
Old May 5, 2010 | 04:14 PM
94exa2's Avatar
absolutely a d16 without a doubt. D-series.org !!!!
Old Jun 3, 2010 | 03:30 AM
kpjo4's Avatar
Here is a link for more in depth about the ZC motors; and yes they are D series.
Dohc zc specs,mods, parts list - D-series.org
Old Sep 10, 2010 | 10:06 PM
neubie's Avatar
as the others stated yes it is indeed a d series, but be sure to research the parts list, there are MANY parts that you need to order from either an 88/89 teg, but as for the dist, the 86/87 teg uses a vacuum advance dizzy, but t-belt for the zc is from a prelude si, timing belt tensioner is for a 88/91 crx (the teg will not work)
which manifold? the zc port spacing is different from the dohc vs the sohc( intake and exhaust) the only way you'll get a sohc intake on, is by buying the adapter plate from zcspeed.com, OR you buy an obd1 dohc zc head
exhaust: any d series exhaust manifold will bolt RIGHT up, but mild porting on the exhaust manifold flange may be rquired as the port spacing is shifted about 1mm ,
d-series.org FTW
for specific dohc zc material: thezcr.com FTMFW
Old Feb 11, 2011 | 09:47 AM
DelSolz6's Avatar
^ +1
Ran a d-series mani on my old zc, just gotta port it a little bit
93sols1
Mar 17, 2010 07:34 PM
hotintegranights
Feb 2, 2006 07:02 PM
genxperformance
Jul 24, 2005 05:10 PM
genxperformance
Jul 17, 2005 12:50 AM
Scottsi
Jan 17, 2005 05:27 PM
