size are the inlet/outlets of the intercooler is 65 mm. but im am not using them. My plan is to change the inlet/outlets to either 2 or 2.5 pipes. The pipes i will of course adjust so they are pointing in the right direction (turbo and plenum)
Bell intercoolers looks very nice, but I bought mine for approx. $ 60 and I think I will keep it
I think i will go for the 2.0 inch pipes, and i agree, it will look better.
I am going to buy this set of pipes i see what i can do with it (PIPE2)
http://turbomotor.dk/contents/da/d18.html
To coxy:
"Especially on a Motorcycle I would look at a Mazda GTX Turbo type bypass valve to circulate boost pressure when the throttle is closed,anti lag style and the safety BOV type as used on Nissan Turbos as a backup set a few psi higher,that should give the best of both worlds throttle response and a safety valve to keep it all from over boost or boost creep issues"
I will study what this is al about. This is my first build and i am learning :-)
Thanks guys, for the answers
